Water in Spare Tire Well? - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 4 (permalink) Old 05-14-2014, 09:57 AM Thread Starter
JBronski's Avatar
Well i have a very annoying problem. I was looking around in the trunk the other day and i noticed there was some water in the spare tire well. The carpet isn't wet and there is no signs of water damage anywhere, so what could it be? I do have a spoiler (its stock LT one), could it be coming from where its bolted to the trunk lid?
JBronski is offline
post #2 of 4 (permalink) Old 05-14-2014, 10:03 AM
Dustinb855's Avatar
Could be. Easiest way to find the leak is remove all the carpeting and dry out the trunk. Then have you or your buddy climb into the trunk with a flashlight while you on the outside of the car spray water all around the seems of the trunk. Your friend will be able to find the leak.
Dustinb855 is offline
post #3 of 4 (permalink) Old 05-14-2014, 06:46 PM
Batmobile's Avatar
I just remembered a good joke. Roll her around in flour and look for the wet spot.
Batmobile is offline
post #4 of 4 (permalink) Old 06-10-2014, 05:25 AM
jignaczak's Avatar
I had that happen too, it was coming from the antenna, the bracket on the antenna base broke so the antenna was moving around, and water was leaking into the trunk
Try to wiggle your antenna around, if it moves, that's the likely culprit
Also, is your third brake light warped, I have seen that happen before as well
Sent from AutoGuide.com App
John
2008 Cobalt LT
SS springs and Stagg struts
Pioneer AVIC-X930BT GPS
jignaczak is offline
