Removing Glove Compartment Panel? - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 15 (permalink) Old 05-21-2014, 09:23 AM Thread Starter
Is there a how to on this?
I wanna spray paint the panel in front of the passenger side black and the bit in front of the driver, the driver's side is easy to remove but I can't figure out passenger.
Has anyone done this before?
mnosz is offline
post #2 of 15 (permalink) Old 05-21-2014, 10:10 AM
swanman35's Avatar
OK to remove the glove box.
The first thing I do is remove the "string" on the right side of the glove box. Yyou pull the whole black plastic "bracket" towards you. You can see the two holes, snap it in the larger whole and slide it out the side. (It can be a bit stubborn, it takes some force)
Then after you remove that, I pull the side of the glove box in to the centeer. You do this to get those 2 pieces that rest in the tracks out. They're the pieces with rubber boots on them.
After you do the the box will fall all the way down, dumping anything in there on the floor.. so empty it first. When it falls down it will expose a number of screws holding the box on the hinge, remove those and you're done.
swanman35 is offline
post #3 of 15 (permalink) Old 05-21-2014, 10:50 AM Thread Starter
thanks i will be doing this very soon i will let you know how it goes.
mnosz is offline
post #4 of 15 (permalink) Old 05-21-2014, 11:16 AM
swanman35's Avatar
OK great. If you have any more questions make sure to post them up, and make sure to post pictures after you paint!
post #5 of 15 (permalink) Old 05-24-2014, 04:22 PM Thread Starter
ive completed this aswell as done part of my dask outline, i will post pics soon after i clean up my interior
mnosz is offline
post #6 of 15 (permalink) Old 05-24-2014, 05:32 PM
swanman35's Avatar
Sounds good!
post #7 of 15 (permalink) Old 05-24-2014, 07:46 PM
I replaced mine without removing any screws...
post #8 of 15 (permalink) Old 05-25-2014, 06:03 AM
rains_crusader's Avatar
^ this
rains_crusader is offline
post #9 of 15 (permalink) Old 05-25-2014, 09:04 AM
swanman35's Avatar
Maybe I was thinking about a different car I did. Either way he got it done. Once you get down to that step you should be able to see how it comes off
post #10 of 15 (permalink) Old 05-25-2014, 12:05 PM
Might want to check the cabin air filter while the glove box is out of the way. I changed mine at around 60k miles and it was filthy.
