LED switch back problem - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 18 (permalink) Old 07-27-2014, 10:45 AM Thread Starter
Clarky215285's Avatar
I got some led switch back bulbs on eBay and installed them with resistors. My problem is if the DRL is on and I use the turn signal the bulb remains white and flashes a little amber but not noticeable enough for a turn signal from far away. Why doesn't it switch back?
---------- Post added at 01:45 PM ---------- Previous post was at 01:30 PM ----------
2005 Chevy cobalt 2.2l base
Clarky215285 is offline
post #2 of 18 (permalink) Old 07-27-2014, 12:04 PM
Do you have the link to the bulb?
post #3 of 18 (permalink) Old 07-27-2014, 12:12 PM Thread Starter
Look at this on eBay:
http://pages.ebay.com/link/?nav=item...d=360960587769
2x T25 3157 60 SMD LED Amber/White Running Brake Switchback Light Lamp Bulb US
post #4 of 18 (permalink) Old 07-27-2014, 12:29 PM
That is not a true switchback bulb. read the specs.
Socket type: 3157, (Dual filament , White and Amber functions.)
post #5 of 18 (permalink) Old 07-27-2014, 12:30 PM Thread Starter
So what kind do I need to look for?
post #6 of 18 (permalink) Old 07-27-2014, 01:17 PM
I think 05-06 use the 3157 CK standard socket configuration. This means a regular 3157 can be inserted which ever way and it will still work.
So you need a switchback that meets these criteria.
---------- Post added at 05:17 PM ---------- Previous post was at 05:15 PM ----------
So this one would probably work for you plus it has cree in DRL mode.
2X 3157 Dual Color White Amber Switchback High Power LED Turn Signal Light Bulbs | eBay
post #7 of 18 (permalink) Old 07-27-2014, 01:24 PM Thread Starter
That one says in the description is doesn't support 3157ck socket though.
post #8 of 18 (permalink) Old 07-27-2014, 01:29 PM
Uh! I believe it says DO NOT FIT 3157CK/SRCK type socket
post #9 of 18 (permalink) Old 07-27-2014, 01:31 PM Thread Starter
Yeah so if I have a 3157ck socket in my 05 doesn't that mean that bulb won't work?
post #10 of 18 (permalink) Old 07-27-2014, 01:35 PM
OddWolf's Avatar
These are the one's I have and never had a problem with them. There's no white when it turn to amber.
http://www.ddmtuning.com/Products/31...-CK-Compatible
OddWolf is offline
