Interior and Headlight Question - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 8 (permalink) Old 01-27-2015, 06:18 PM Thread Starter
Hey,
I have 2 questions. Firstly, the lights for the HVAC control panel, are they soldered in LEDs or just small bulbs in a socket?
Secondly, I have Gen 1 headlights and am looking to rebuild them. Does anyone know what I would need? Are there any power inverters or amplifiers, ring size in the headlights, etc.
Thanks,
Randy
RanMan77 is offline
post #2 of 8 (permalink) Old 01-29-2015, 03:56 AM
Iceman62's Avatar
If the instrument cluster bulbs are like the ones in my 06 Colorado truck (haven't had to replace any in 'Balt yet), they're Neo Wedge type like this:
You can get them here: Neo Wedge
Can't assist w/the headlamps...mine are stock, but I'm sure another member will chime-in soon. Good luck!
MSgt, USAF (Retired)
Iceman62 is offline
post #3 of 8 (permalink) Old 01-29-2015, 04:31 AM
HVAC backlight bulbs are 4.7mm soldered on the board supported by a square plastic base.
I replaced mine with 12 volt LEDs. Arrows indicate negative side of LED.
They solders on nicely if you bend the leads this way. Before you cut the leads, the longer lead is always positive. If you cut the leads like I always do you can identify the leads if you look through the LED lens where the arrow is pointing you will see the black resistor on the positive side of the LED or negative side has a flat spot on the rim.
post #4 of 8 (permalink) Old 01-29-2015, 11:12 AM
JBronski's Avatar
That looks really good. How hard was it to solder the LED leads to the board?
JBronski is offline
post #5 of 8 (permalink) Old 01-29-2015, 11:43 AM
beaverG5GT's Avatar
Coby, where do you order your 12 volt LEDS from.
beaverG5GT is offline
post #6 of 8 (permalink) Old 01-29-2015, 11:47 AM
Just preflow a bit of solder on the board islands then remelt to the leads.
---------- Post added at 03:47 PM ---------- Previous post was at 03:44 PM ----------
Originally Posted by beaverG5GT View Post
Coby7, where do you order your 12 volt LEDS from.
http://led-switch.com/12%20volt%20LED.htm
post #7 of 8 (permalink) Old 02-09-2015, 09:41 AM
beaverG5GT's Avatar
How would red leds look for for the HVAC controls.
How are the Radio lights attached
post #8 of 8 (permalink) Old 02-09-2015, 10:29 AM
Red is going to change the blue decals to purple.
