Dash Cam Installation - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 25 (permalink) Old 02-04-2015, 07:29 PM Thread Starter
Clarky215285's Avatar
Hey guys, lately I have been looking into dash cams. I have two concerns that I need answers for before I make a decision.
1) Is it just me or do the cigarette lighter ports have power even when the vehicle is off? Is there a way to stop that?
2)If I were to hardwire my dash cam to turn on when the car turns on, where would I tap into a power supply?
Clarky215285 is offline
post #2 of 25 (permalink) Old 02-04-2015, 07:39 PM
Dustinb855's Avatar
The power outlets stay on when the car is off. The other questions I don't know lol.
WRX are as nice as they get.
Dustinb855 is offline
post #3 of 25 (permalink) Old 02-04-2015, 08:29 PM
On the interior fuse panel on the passenger side footwell, fuses 15 wipers and 19 steering wheel control are powered only when the car is in run. I power my GPS and gauges from these two with an add a circuit.
http://www.amazon.com/Bussmann-BP-HHH-ATM-Add-A-Fuse/dp/B000GKEXK2Buy yourself a cheap power extension
url="Http://www.amazon.com/gp/aw/d/B00065L2D8"]Roadpro 12V Battery Clip-On and Cigarette Lighter Adapter:Amazon:Automotive[/url]
Can't get the link working, but type roadpro 12v battery clip on into Amazon.
Cut the clip ends off, wire the add a circuit to the positive and ground the other end under a bolt touching the frame near the fuse panel and voila, you have power that shuts off when the key is in acc or off. You don't have to damage the cable on your dash cam. Just hide the wires under the dash. A few zip ties and some wire loom will aid in hiding the wires and keep them from rubbing on anything, but are unnecessary.
dakotarayne is offline
post #4 of 25 (permalink) Old 02-04-2015, 09:43 PM Thread Starter
Amazon.com: Bussmann BP/HHH ATM Add-A-Fuse: Automotive
pics?
post #5 of 25 (permalink) Old 02-05-2015, 05:45 AM
Sorry for the quality of the pictures. All I have available is my phone camera. Everything is already installed, which makes it more difficult... For my GPS, i used the WIPER fuse.
Here is the passenger side fuse panel. The positive wire off the power extension is in green, for visibility. The ground is in yellow and runs from the end of the power extension, through the wire loom, to where I grounded it. I have a picture of that below. For the end of that wire, I got an end that was a metal circle, crimped it on, and put the bolt through the center and tightened it back into the frame. (There are two power wires because I have another wire powering my gauges. You should only have one add-a-fuse wire)
Here is the add-a-fuse pulled out. the original fuse goes in, as well as a new fuse rated for your application. The additional fuse should be of the same value or less as the fuse that you are tapping, not to exceed the rating of the add-a-fuse. To ease installation, I ran 18Gauge wire from the add-a-fuse to the other side of the car and attached it to the end of the power extension. That allowed me to run the wires without stretching them.
Here is where I grounded the circuit.
This is a shot on the drivers side looking under the dash. The power extension plugs directly into the car adapter for the GPS unit.
Run the gps wire up the drivers side of the dash to keep hidden.
Pull out enough so you can attach to the gps.
Sorry for the terrible write up, but if you have any questions, let me know. It is a pretty simple job. I used heat shrink on all the connections where I put two wires together, or added some kind of end. I tried to wire loom all of the wires as well, so they don't rub on anything. In all, it took maybe 30 minutes.
post #6 of 25 (permalink) Old 02-05-2015, 06:03 AM Thread Starter
Do you remember if they are atc or atm fuse taps?
post #7 of 25 (permalink) Old 02-05-2015, 08:35 AM
Atm
post #8 of 25 (permalink) Old 02-05-2015, 09:10 AM Thread Starter
Coby7 has also mentioned using the HVAC fuses.
post #9 of 25 (permalink) Old 02-05-2015, 10:26 AM
I don't remember why I didn't use hvac. Maybe the wire on the add-a-fuse stuck too far out. It is an option too.
post #10 of 25 (permalink) Old 02-06-2015, 01:52 PM Thread Starter
So to make sure I understand. Pull the fuse, put fuse in slot on tap, put tap in the fuse panel, crimp the wires, and attach a negative cable from my dash cam wire to a bolt on a metal surface.
