Window Motor, Gear Shift, and Turn Signal - Page 2 - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #11 of 20 (permalink) Old 09-03-2015, 10:06 PM Thread Starter
Britnisima's Avatar
Originally Posted by rrob5382 View Post
The motor and regulator do seperate, you can change just the motor if that's the route you want to go, although I'm not entirely sure that's your problem. I would lean more towards the switch itself probably, if not the wiring or a connection somewhere
---------- Post added at 03:07 PM ---------- Previous post was at 03:07 PM ----------
As far as the other two, just follow those links. Coby did a great job with those write ups as usual
Since it had gone through its temperamental phases of working and not working I don't think it's the switch. I feel like it would have just stopped working and never worked again but since it keep occasionally working I feel like the motor was just on it's way out. I bought my car from enterprise car sales a few years back and I'm certain the window has had its fair share of usage. I live in florida and we have lots of tolls to pay and gate codes to enter etc. lol. If I install the new motor and it doesn't work I guess I'll have to look at other options.
---------- Post added at 09:01 PM ---------- Previous post was at 09:01 PM ----------
I haven't had a problem with my armrest breaking.
So I was able to order the parts I need on amazon. I took the turn signal lever out and flipped the metal piece over (I found a video the recommended this to see if it eliminated the problem) which did not help my problem but at least thats a pretty simple fix.
The window motor I feel will be the most challenging since I've never done anything similar to that before, but I'm guessing it can't be that difficult since it seems like it's a few screws and clips. So I'm going to attempt that one this week once I get the new motor.
---------- Post added at 09:06 PM ---------- Previous post was at 09:01 PM ----------
Originally Posted by Parthros View Post
Check out this thread. There's a tear down of an auto shifter which shows the part you're talking about. You might be able to glue or tape it back on. If I were having the problem, I'd probably try to get creative about it.
https://www.yourcobalt.com/forums/int...c-shifter.html
The turn indicator lever problem is pretty common. You can fix it yourself, but I'd probably buy a new one if it were me. Again, there's already a great thread about this.
https://www.yourcobalt.com/forums/int...nal-lever.html
Did you write these? These are amazing! The thread about the turn signal is the one I found that prompted me to try flipping the metal rod in the signal lever. It didn't help in my problem but now I know how to fix it with the new piece.
Do you know if there is a write up on how to actually get the gear shifter out of the center console? Would I have to remove all the trim around it down to the armrest to remove it?
Britnisima is offline
post #12 of 20 (permalink) Old 09-04-2015, 03:21 AM
Just have to remove the top trim, clip on shifter cable and 4 nuts. Oh and the small connector going to it.
post #13 of 20 (permalink) Old 09-04-2015, 06:42 AM
Parthros's Avatar
Thumbs up
Haha, no, but I'd love to take credit anyway! Coby7 is the genius behind these two write ups.
Parthros is offline
post #14 of 20 (permalink) Old 09-06-2015, 02:00 AM Thread Starter
Britnisima's Avatar
The turn signal went in no problem! One down, and time to tackle another!
post #15 of 20 (permalink) Old 09-06-2015, 05:54 AM
The trick with any vehicle is to fix whatever breaks down as soon as possible. If you let the problems accumulate then it becomes overwhelming.
post #16 of 20 (permalink) Old 09-06-2015, 01:36 PM Thread Starter
Britnisima's Avatar
Ok so now I hve another question...I'm sure the answer is no but hey maybe it's normal. So I was taking apart my door today to fix the motor and since I live in florida it started to downpour. I closed the door and finished removing some screws and then was going to wait until the rain stopped to continue. Well while I was in the car I noticed there is leaking inside the door frame. I've never noticed this before since it's not inside the car and nothing ever gets wet. Is it normal to have a little leakage inside the frame of the car that we can't usually see. Even if it is I'd like to fix that because water and electric don't mix and I like my pioneers lol.
I'm wondering if the window is just not fully shut or if it's the seal around the door. I guess if it was the door seal I'd have water in the car, right?
post #17 of 20 (permalink) Old 09-06-2015, 01:51 PM
rrob5382's Avatar
I could be wrong here but I'm pretty sure it's normal to get a little water in there from time to time
rrob5382 is offline
post #18 of 20 (permalink) Old 09-06-2015, 11:47 PM Thread Starter
Britnisima's Avatar
Window motor went in. I had a bit of difficulty but mainly because I've never done this before. but I can successfully roll down my window!
post #19 of 20 (permalink) Old 09-07-2015, 04:19 AM
Does this mean it won't roll back up lol
post #20 of 20 (permalink) Old 09-14-2015, 11:08 AM Thread Starter
Britnisima's Avatar
lol. it is working properly
gear shift , regulator , turn signal , window , window motor
