How to Change Coolant in Cobalt 2.2l - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 6 (permalink) Old 07-07-2010, 05:58 PM Thread Starter
Exclamation How to Change Coolant in Cobalt 2.2l
I have been having a hard time getting all the old green coolant out of my 07 cobalt, i drain it and then try to fill it with water and all i can add is what will fit in the coolant resv. i'll trun it on and run it but the old coolant wont come out of the motor. temps are 190-210. heater works fine. is there a DIY coolant change on here??
cobrajet is offline
post #2 of 6 (permalink) Old 07-07-2010, 11:00 PM
GpB311's Avatar
If the search function here doesnt turn up anything favorable, I always try google. Googling "how to change coolant in chevy cobalt" brought me this.
How to Flush the Radiator in a Chevy Cobalt | eHow.com
---------- Post added at 11:00 PM ---------- Previous post was at 10:59 PM ----------
hmmm, it seems I misread. So you can drain it, but then you go to refill it and it wont drain from the reservoir down into the radiator?
GpB311 is offline
post #3 of 6 (permalink) Old 07-07-2010, 11:02 PM
my coolant is orange
post #4 of 6 (permalink) Old 07-08-2010, 06:40 AM
finnscobalt's Avatar
You should look and try to find the Chilton or Haynes repair manuals. They can usually be found at Autozone or Advance. They have alot of the common repair stuff.
sig pic courtesy of GBALT05
finnscobalt is offline
post #5 of 6 (permalink) Old 07-08-2010, 08:50 PM
Nice try green coolant? Ha!
The Chevy Cobalt like every other Chevy after a certain year uses Dexcool which is Orange. Dont use the green coolant because you will destroy your engine, and cooling system. Dexcool + Green Coolant acts like a acid.
Just drain the coolant out of the botom with the plug, make sure not to spill any on the ground, put a low power water hose into the radiator and let it run water through drain all water, then refill the radiator with the plug back in with Dexcool only.
darklide is offline
post #6 of 6 (permalink) Old 07-08-2010, 09:01 PM
good ol darklide
