Cooling System Flush - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
 1Likes
LinkBack Thread Tools
Old 09-13-2013, 02:50 PM Thread Starter
Clarky215285's Avatar
Has anyone flushed their cooling system? I know to use only distilled water but I didn't know if there was a "how to" on here.
I have a 2005 Chevrolet Cobalt 2.2L base coupe and the overfill reservoir has orange coolant in it.
Thanks!
Clarky215285 is offline
Old 09-14-2013, 11:27 AM Thread Starter
Anyone?
Old 09-16-2013, 05:20 PM Thread Starter
Bump....
Old 09-16-2013, 08:04 PM
Batmobile's Avatar
I flushed mine by simply opening the drain plug and letting a garden hose run through the resivor( I can't spell for shit right now sorry). I've heard to start the engine while the hose is running but I didn't.
Batmobile is offline
Old 09-17-2013, 10:58 AM
The orange coolant is called Dex-Cool. It's made specifically for the ecotec engines. You can use traditional green coolant, but the two don't mix well together. Other wise, change it the way you would any other car.....
Ridinonrails is offline
Old 09-17-2013, 01:43 PM Thread Starter
I see that there isnt a radiator cap to replace the coolant and burp the system. I can do all of that at the overflow tank correct?
Old 09-17-2013, 04:20 PM Thread Starter
Getting to the drain plug sure is a pain in the ass
Old 09-18-2013, 10:53 AM
Yes, & I cut out a small section in the black splitter for easier access to plug & drainage. Use a pair of tin snips - works the nuts.
Old 10-06-2013, 05:53 PM
There is a plug at the back of the water pump pointing straight down. (On the Passenger side.) You can't see it front so you have to do it by feel. Take to plug out to completely drain the coolant. You can use a standard 3/8 short handled ratchet. I used 100% Prestone Dexcool for GM vehicles. (Orange)
SteveH08G5 is offline
Old 02-02-2014, 02:00 PM
Pulling the lower rad hose works well too
short4stuff is offline
