2000 Cavalier Spedometer Wont Work - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 9 (permalink) Old 02-05-2010, 08:26 PM Thread Starter
not the whole cluster but just the spedometer. it is stuck at 0 mph
could this be the wiring or a fuse or just the whole cluster needs to be replaced??
i dont wana buy a new one and find out it still dosnt work.
any ideas??
05c08a!t is offline
post #2 of 9 (permalink) Old 02-05-2010, 10:29 PM
Levee
Admin
Leveecius's Avatar
Might be a fuse. Check your fuses for your cluster. Does your ABS light come on? When you turn the key on, does the gauge move at all (only turning the key from off to run *NOT* starting it)?
'09 SS/TC - Stolen
06 EVO IX MR/SE - Sold
'95 Ram 2500 Diesel
Speed Junkies Social Group
Leveecius is offline
post #3 of 9 (permalink) Old 02-06-2010, 12:03 AM Thread Starter
the spedometer arrow thing never moves at all...the car is actually my moms and i think all the other lights work.
how do i tell if a fuse is blown??
05c08a!t is offline
post #4 of 9 (permalink) Old 02-06-2010, 11:53 AM
Levee
Admin
Leveecius's Avatar
When you pull it out of the fuse panel the metal in the plastic will be blown apart. Ask if the ABS light is on. It sounds to me like a VSS to me. If it is, the ABS light will be on. If not, then the speedo isn't getting input from the ECU.
'09 SS/TC - Stolen
'95 Ram 2500 Diesel
post #5 of 9 (permalink) Old 02-06-2010, 01:08 PM Thread Starter
so what do u think it is a sensor wire, wiring, fuse, or whole cluster??
05c08a!t is offline
post #6 of 9 (permalink) Old 02-08-2010, 05:50 AM
Levee
Admin
Leveecius's Avatar
If the needle doesn't move, it's more than likely the cluster.
'09 SS/TC - Stolen
'95 Ram 2500 Diesel
post #7 of 9 (permalink) Old 02-08-2010, 09:10 AM
black-balt's Avatar
even if it is the cluster, it's very cheap and simple to replace, you just have to go to the junk yard, I bought one for my cav for like $20, and takes about 20 minutes to swap them out
2008 Cobalt LS 2.2
black-balt is offline
post #8 of 9 (permalink) Old 02-08-2010, 09:16 AM
Rocket Power
YourCobalt of the Month WinnerAdmin
RocketFoot's Avatar
Sounds like a VSS to me...I'm not familiar with Chevy's but My Ford Taurus suffered from the same symptom. Turns out that there were 2 VSS parts, one was easy to change on the top of the axle, but my problem was the driven gear part deep inside the tranny.
Yea, tho I cruise through the valley of the shadow of rice, I will fear no Turbo,
for Torque art with me. Thy rods and crankshaft, they comfort me.
RocketFoot is offline
post #9 of 9 (permalink) Old 02-08-2010, 10:33 AM
Levee
Admin
Leveecius's Avatar
^^ These are the same way, but if a VSS is out, the ABS light would be on, the ABS would be inactive, and the needle will still move if the power to the cluster is turned on. If the needle doesn't move at all, then it's the cluster. ;)
'09 SS/TC - Stolen
'95 Ram 2500 Diesel
