Jury-rig Exhaust Support? - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 3 (permalink) Old 11-20-2018, 09:22 AM Thread Starter
(2007 LS auto)
The middle pipe (aka 'resonator') [1] on this car has two support points. Both consist of a barbed rod welded to the chassis with a rubber 'insulator' hanging from it. Another rod welded to the pipe plugs into the 'insulator'. In my case, both rods have broken off the pipes. This leaves the whole exhaust hanging between the manifold connection and the rear muffler hanger.
I obviously have to replace the resonator/pipe (and the converter, but that's a separate story), but this isn't a great time for doing so.
Quest: has anyone found a way to 'temporarily' support that pipe? All I can think is to drill a hole in the underbody and tap a screw into it, to support some universal hanger. I'm not sure the metal there would be thick enough to give good support.
[1] exhaust diagram: https://www.rockauto.com/en/moreinfo...0476&jsn=10476
ge315 is offline
post #2 of 3 (permalink) Old 11-20-2018, 09:37 AM
rooster4321's Avatar
An Independent Muffler Shop could probably fix it for under 50 bucks
Sent from my KYOCERA-E6560 using Tapatalk
rooster4321 is offline
post #3 of 3 (permalink) Old 11-20-2018, 11:06 AM
Whatever you do don't drill through the floor it will rot fast enough on it's own. If the 'insulators' are still there just run hanger wire around the pipe and through the hanger until you can get it to a shop.
exhaust system , mounts
