Cobalt LNF No Boost - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 12 (permalink) Old 12-03-2018, 11:21 PM Thread Starter
Cobalt LNF No Boost
2008 cobalt ss/tc doesn’t build any boost, boost gauge goes through vacuum just fine then when it hits 0 it doesn’t go into boost. The car doesn’t have a Check Engine Light On, but the abs, traction control, and Tpms lights are on due to a rear wheel speed sensor.
Djsalaba18 is offline
post #2 of 12 (permalink) Old 12-04-2018, 04:03 AM
Did you pressure test the plenum for leaks?
post #3 of 12 (permalink) Old 12-04-2018, 03:00 PM Thread Starter
Yes I did, the only place I could feel, hear air is on the turbo, the steel braided line that goes to the very left of the valve cover. Also I took the oil cap off while doing the test and it was pressurized as well.
post #4 of 12 (permalink) Old 12-04-2018, 07:13 PM
Is your waste gate moving freely? It might not be closing all the way.
post #5 of 12 (permalink) Old 12-05-2018, 06:29 AM Thread Starter
How do I test it? I checked to make sure that it’s had the 2 nuts that fall off and they are still there.
post #6 of 12 (permalink) Old 12-05-2018, 05:24 PM
gm has a couple service bulletins about no boost - 1 was about the nuts for the wastegate rod which you just said are there and 2 was about the passenger side radiator support mount bolts would rub through the air charge tube
i fixed my buddies lnf no boost issue/no codes by changing the boost bypass solenoid mounted on the intake manifold
TCSS07 is offline
post #7 of 12 (permalink) Old 12-05-2018, 09:06 PM Thread Starter
Is there a way to test the solenoid? And now that I drove it in the daylight I see there’s quite a bit of smoke coming from the tailpipe.
post #8 of 12 (permalink) Old 12-06-2018, 06:08 PM
you need the gm tech 2 to command the solenoid on and off and listen for a audible click noise and if no noise is heard the solenoid is probably dead but to check the wiring just connect the connector to a test light and command it on and off and see if your test light lights up
TCSS07 is offline
post #9 of 12 (permalink) Old 12-07-2018, 05:19 AM Thread Starter
So the solenoid clicks when hooked up to power, still haven’t tried anything with the wastegate(Dont know how to test).
post #10 of 12 (permalink) Old 12-08-2018, 10:59 PM Thread Starter
Tested the wastegate and it moves freely, now getting p0238 and p0098.
