Losing Coolant - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 3 (permalink) Old 02-24-2019, 05:19 PM Thread Starter
Losing Coolant
2008 Cobalt, 341xxx km
losing coolant, but i'm not sure where
i've topped the coolant up exactly two times in owning this car for more than six years, both times in the last 12 months
i noticed it looked low the other day so i filled it back up to the full mark on the overflow (still had the coolant in the trunk), and now it's low again.
i did a fairly thorough once over at all the coolant hoses, the rad, and really anything and everything in the engine bay that looked remotely like a coolant line (have a valvecover leak, but that's not really overly concerning at the moment)
no obvious signs of leakage
pulled the plugs to see what they looked like; all good there, no signs of coolant there either
checked the dipstick/fill point on the valvecover; no signs of milkshake
any ideas? no change in mileage or performance, no white smoke, no sweet smell of antifreeze in the interior from the heater core or anything
theroadvirus is offline
post #2 of 3 (permalink) Old 02-24-2019, 06:08 PM
rooster4321's Avatar
Remove the large plastic cover on the engine now from The fill tank is a rubber hose and then a steel tube across the front of the engine mine was rubbing on something and a small hole leaked that was not dripping but still leaking when hot
Sent from my KYOCERA-E6560 using Tapatalk
rooster4321 is offline
post #3 of 3 (permalink) Old 02-27-2019, 06:13 PM
radiator,water pump,heater core or head gasket if you don't see any external hose leaks. pressure test it and let it sit overnight and or let it get hot and use a a head gasket checker
TCSS07 is offline
Similar Threads
JW if Orange Coolant is the Stock Coolant NDcobalt Engine Mods 14 03-07-2012 05:45 PM
Losing the Lower Grill jimiballs Interior & Exterior Styling 23 07-30-2011 05:41 PM
Losing power...can anyone help? davkojr Problems and Service 16 01-06-2010 01:02 PM
Problem with Surging and Losing Power. black06SS Problems and Service 12 01-02-2010 11:04 AM
Losing my clearcoat?!? Quahogmafia Interior & Exterior Styling 8 05-13-2009 04:58 PM
