P2101 and p1516 please help - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 3 (permalink) Old 03-20-2019, 07:37 PM Thread Starter
I have spent days searching the web and I cant find a solution. I bought brand new ac delco throttle body with the sensor, o2 sensors, gas pedal with sensor, cut and placed a new connector to the throttle body harness. I dont know what else it could be!!! I have unplugged the battery and clear the codes and it keeps coming back. Funny part is I can drive in reverse with no problem but the second I put it in drive and I touch the gas BAM engine power reduced and traction is turn off. Can anyone please help me out this is my daily!!
Jay2nice000 is offline
post #2 of 3 (permalink) Old 03-27-2019, 01:32 PM
The throttle body will have a learn process to determine the valve location. Have you tried going through that process with the car idling?
Start with disconnecting the battery to reset the ECU and then follow the procedure that you can search for in the forums.
Good luck.
Topher is offline
post #3 of 3 (permalink) Old 03-27-2019, 07:18 PM
start looking around for some possible wire chaffing and unless you have access to a multimeter or scanner to give you data to check the circuits from the tb to the ecm your shooting blind. so you may want to have a dealer take a look. both those codes are for the tac module performance which is the tb. the ecm stores the idle position and i have seen ecms unable to learn the idle position after a tb replacement which may or may not set a dtc but if it did it would be a p2176
TCSS07 is offline
Similar Threads
P0120 P0220 P2101 No Start Dis Juan Problems and Service 3 09-07-2015 05:15 PM
This is Driving Me NUTS!!! Please PLEASE Any Words of Wisdom mrzombiefingers Problems and Service 18 01-06-2015 08:32 PM
Need Help with My 2007 Cobalt! PLEASE HELP babybalt Chevy Cobalt Owners Lounge 0 09-10-2014 06:31 AM
P1516 help Jmac23 Chevy Cobalt Owners Lounge 6 08-26-2014 12:36 PM
Please help me with info!!!!please golfin Suspension/Wheels/Brakes/Tires 10 10-19-2009 07:32 PM
