Timing chain and low compression - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 5 (permalink) Old 03-23-2019, 08:51 PM Thread Starter
Hey guys I have some experience with rebuilding Jeep engines and I want a cobalt as a daily driver, but it needs work. First of all, it's a 07 LT 4d I think for $500 and needs a new timing chain and has low compression in 2 cylinders and it's been sitting for about 2 or 3 years. Is that a decent price? Now for the actual questions: how hard is a timing chain to replace in the 2.2L engine? Does it require taking the engine out? I dont want to get it if it's going to be too much of a hassle to fix. Also, it has low compression in 2 cylinders which I heard could be because of the timing chain that jumped a little bit and/or is loose. Should that be a concern? Thanks
Djbtraxxas is offline
post #2 of 5 (permalink) Old 03-24-2019, 07:43 AM
ericvmax's Avatar
It's very simple, you will found the timing chain kit for less then 100$ on a bay, no specials tool needed exept a torque wrench, you can reuse the side carter gasket but you need a new head cover gasket.
ericvmax is offline
post #3 of 5 (permalink) Old 03-24-2019, 10:15 AM Thread Starter
Awesome thanks for the reply. So the engine doesnt need to be removed? My dad got a Toyota matrix that needed the engine removed to replace the timing chain so I dont wanna go through all that anymore.
post #4 of 5 (permalink) Old 03-25-2019, 04:56 AM
ericvmax's Avatar
You are supposed to discard the old crank and sproket bolt but when I do it I kept the old ones because it was not include in my kit.
---------- Post added at 03:56 AM ---------- Previous post was at 03:42 AM ----------
Sitting for 2 or 3 years is may be the reason why you have low compression on 2 cylinders, Try an another test after driving a few hundred kilometers.
ericvmax is offline
post #5 of 5 (permalink) Old 03-25-2019, 05:49 AM
Timing chain itself is fairly easy, just take your time and ensure all is lined up before things go back together.
Your big issue with this project, if you have low compression in 2 cylinders coupled with a timing chain issue, you likely have bent valves as well. You can check this by looking at the rockers when the valve cover is off. If you can wiggle or remove them by hand when that cylinder is at TDC, the valve is toast. The head will need to come off for rebuild/replacement.
2010 LT 2.2 4 door
montagc is offline
Similar Threads
Timing chain tensioner and headgasket simultaneously? tvanderpan93 Problems and Service 8 05-16-2016 09:44 AM
Timing Chain/balance Shaft Chain jmix Engine Mods 2 06-23-2015 07:53 AM
06 Cobalt 2.2l Low Compression aka21 Problems and Service 12 03-23-2015 02:11 PM
Timing Chain and Tensioner Replacement THKbolt Problems and Service 28 12-14-2013 04:39 PM
Timing Chain or Timing Belt. Chester Chevy Cobalt Owners Lounge 9 11-13-2009 02:40 AM
