P0171 p2135 - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 3 (permalink) Old 05-10-2019, 07:45 PM Thread Starter
hawaii icon
agita_san's Avatar
P0171 p2135
So a couple weeks ago I Got the 2 trouble trouble codes p0171 p2135 and went into limp mode. I turned the car off, cleared the codes and only p0171 came back and has been on consistently. I've changed the fuel filter, checked the vacuum lines, cleaned the maf adn air filter. Nothing has helped yet. Then today p2135 came back and put me into limp mode again. So I'm wondering how the 2 of them can be connected? I'm kinda at an impasse here....
agita_san is offline
post #2 of 3 (permalink) Old 05-11-2019, 08:35 AM
P2135 Throttle Position (TP) Sensor 1-2 Correlation ECM
They are very related. I believe on the Cobalt the throttle position sensor is built into the throttle body itself. You could try cleaning the connectors contacts but chances are you will need a new throttle body. Most can be swapped without a relearn provide the keys are in you pockets and not in the ignition when you do so.
post #3 of 3 (permalink) Old 05-15-2019, 08:43 AM Thread Starter
hawaii icon
agita_san's Avatar
I was able to get rid of the P2135 code. One of the wires insulation was worn out and the wire was expoed a bit. Re-soldered it and its good to go, but the P0171 code is still being a problem. I was able to finally find a vacuum leak. I fixed that, but no change in anything.
Similar Threads
2009 Cobalt P0171 and P0303 lct211 Problems and Service 6 08-13-2014 01:21 PM
P0171-Running Too Lean Bank 1 Shay Problems and Service 6 10-07-2013 03:04 PM
Code P0171, System Too Lean... Recent K&N Ricky Bobby Problems and Service 19 12-15-2012 01:55 AM
Running to Lean P0171 Shay Problems and Service 7 11-24-2012 09:19 PM
Air Intake And Check Engine Light!!! (p0171) nanesnj Chevy Cobalt Owners Lounge 53 08-20-2008 02:02 PM
