Driverside Leak? - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 8 (permalink) Old 06-09-2010, 11:24 AM Thread Starter
tyler14blank's Avatar
Driverside Leak?
So I went out to my car this morning to go to work and it was raining...I got in my car and I heard my feet splashing around in water...there was about a 1/4 inch of water on my floor on the driver side...it only does this when it rains hard...any ideas of what it could be
tyler14blank is offline
post #2 of 8 (permalink) Old 06-09-2010, 11:30 AM
happened to me...idk what the hell is wrong with it...
heres an old thread i made a while back
https://www.yourcobalt.com/forums/che...oard-leak.html
post #3 of 8 (permalink) Old 06-09-2010, 12:00 PM
krazedkitty's Avatar
Do you have a sunroof? Or ever had your windshield replaced? There was a thread on here not too long ago with a similar problem... the problem was their windshield I believe.
krazedkitty is offline
post #4 of 8 (permalink) Old 06-10-2010, 07:51 AM Thread Starter
Nope no sunroof...and never had the windsheild replaced..lifted up the carpet on my driver side and there was a puddle off water...I think maybe the seal around my door isn't sealing properly
post #5 of 8 (permalink) Old 09-04-2010, 08:57 AM
have you made any holes in the firewall to run audio wires? If not seal up properly, you can end up with a leak just like the one you describe.
ethridge is offline
post #6 of 8 (permalink) Old 09-04-2010, 11:23 AM
Eyesore's Avatar
also check around ur cowl.. we fix alot of cars that have leaks and thats usually where it is if it ain't the windshield
Eyesore is offline
post #7 of 8 (permalink) Old 09-04-2010, 11:53 AM Thread Starter
It actually doesn't do it anymore..I took the door seal off and cleaned all around the door and put it back together and it is fine now
Originally Posted by Beamer View Post
no b to b's when you're in the v and the a.
post #8 of 8 (permalink) Old 09-04-2010, 12:10 PM
Eyesore's Avatar
good to hear...if it ever does it again, just clean up the water so its completly dry and get one of ur friends to use a garden house and spray one spot at a time with u in the car looking for the leak...start around the door where it meets the fender, then the wheel well, windshield and then cowl to try and pin point it
Eyesore is offline
