I Need Help, Its an Odd Problem - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 13 (permalink) Old 10-24-2010, 03:29 PM Thread Starter
Ok if this has been talked about before im sorry i wouldnt know how to search for this
My cobalt will work perfect for a day or two no problem, then randomly i hear ding ding and it starts freaking out. The power steering light pops on and off, all my speedometers and gauges keep dying and coming back on, it starts to shift really rough.
This started a while ago, it use to stop after i turn off and back on the car and it would work perfect. It started a few weeks apart, then days and now it happens around a day and a half apart. The security light turns on, and if i drive it while its messed up eventually the check engine light comes on displaying a transmission codes. (its almost light the computers arnt communication properly) But once i take out the fuse by the battery it will work like new for another day and a half and the check engine will go off.
Ive taken it back to chevy and they replaced the power steering motor under the recall. Worked perfectly for two days and it went back to doing it. Ive taken it to a few shops including the one at chevy and after checking all the wires, wire harnesses, and grounds they couldnt figure that out without "taking things apart which would rack up a big bill with no promises"
The cobalt is a 2006 LS 2.2 with 86000 miles.
The only lead i have is MAYBE the ECU computer freaks out after i drive it a certain amount and doesnt work right until i take the fuse out resetting the computer?
Please any help would be great, what can/should i do? has this happened to anyone Thanks so much
joshuadjohnson is offline
post #2 of 13 (permalink) Old 10-24-2010, 03:42 PM
Eyesore's Avatar
have u tried unhooking the battery for 10-15 minutes? It'll reset the computer
---------- Post added at 07:42 PM ---------- Previous post was at 07:42 PM ----------
and welcome to the site by the way \m/
Eyesore is offline
post #3 of 13 (permalink) Old 10-24-2010, 03:51 PM Thread Starter
they might have done that at the dealer but i just unhooked it, i really hope this will work. thanks ill keep you posted. Wouldnt taking out the big fuse in the back do the same thing? Or just partial? thanks again
Edit*
if i remember correctly i took off one terminal and put it back on and it worked great for about 2-3 months, then went back to doing it
post #4 of 13 (permalink) Old 10-24-2010, 04:01 PM
Eyesore's Avatar
sometimes it just has to be reset again, and unplugging the battery for 15 minutes will reset it
Eyesore is offline
post #5 of 13 (permalink) Old 10-24-2010, 04:33 PM Thread Starter
ok i did it, and it remembered all m radio stations, does that mean it didnt work?
post #6 of 13 (permalink) Old 10-24-2010, 04:38 PM
Eyesore's Avatar
it shouldn't remember the presets u did I don't think anyways...did it reset the clock? If it didn't do the clock it was resetted right
Eyesore is offline
post #7 of 13 (permalink) Old 10-24-2010, 04:56 PM
parise9's Avatar
Send a message via AIM to parise9 Send a message via MSN to parise9
i'd go with the clock. i had mine disconnected for a day and half and it remembered all my presets.
parise9 is offline
post #8 of 13 (permalink) Old 10-24-2010, 06:57 PM
^^^ Smart radio. Yeah, just time it a 30 minutes or so... And go ahead and take off both terminals. I mean if you are going to do it go for the gold. lol
post #9 of 13 (permalink) Old 10-25-2010, 04:30 PM Thread Starter
ok, it worked great until tonight. Now no matter if i unplug the fuse or not, it freaks out after about 5 min. I dont know what to do. A old GM manager said he worked on a lot of these and thinks its a short in the steering column that should be covered under the recall, do you think that could be a possibility?
post #10 of 13 (permalink) Old 10-25-2010, 05:42 PM
finnscobalt's Avatar
There was a membe having similar stuff happening, think it was some transmission sensor. Check some of the other posts to find it.
sig pic courtesy of GBALT05
finnscobalt is offline
