P0705 Code?? Any Help Please? - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 5 (permalink) Old 12-07-2010, 05:53 AM Thread Starter
I have a P0705 code. "PRNDL" circuit problem. I have replaced the transmission position sensor, and this didn't help. I am reading that maybe the shifter is the problem. Any ideas on this
---------- Post added at 08:53 AM ---------- Previous post was at 08:49 AM ----------
Oh I also forgot to mention. The doors don't automatically lock anymore when I put the car into gear and the cruise control doesn't engage when I press the cruise control button.
Sonic454 is offline
post #2 of 5 (permalink) Old 12-07-2010, 07:26 AM
RauLiTo's Avatar
Send a message via MSN to RauLiTo Send a message via Yahoo to RauLiTo
I had read before about the shifter not allowing to remove the key..
But maybe you have a loose wire some where .. since you replaced the sensor..
RauLiTo is offline
post #3 of 5 (permalink) Old 12-09-2010, 08:44 PM
Sometimes if your cruise control does not engage or function then you have a broken wire in the systen, and the computer is overriding the cruise control to engange by saying the brake is being applied.
CobaltKatsu is offline
post #4 of 5 (permalink) Old 12-10-2010, 05:37 AM Thread Starter
thanks for the help so far. I am guessing that i may have a break in the wiring somewhere, but i havent found it yet. If i erase the codes, The doors lock once when I put the car into gear the first time, but then I have to wait for approx. 30 seconds because I can't get the shifter to go into gear. Then once it allows me to put the car into gear, i have to manually lock or unlock the doors again because the shifter no longer controls that function. I though that maybe a switch in the shifter was malfuntioning causing this. But at this point I don't really know.
Sonic454 is offline
post #5 of 5 (permalink) Old 12-10-2010, 07:45 AM
Ill look into it today while I'm at work
