2.4 Engine into a 2009 LT Cobalt - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 8 (permalink) Old 09-07-2011, 12:04 PM Thread Starter
I have a 2009 LT Cobalt with 2.2L engine that was overheated. The mechanic replaced it with a 2.4L engine. He said he used the 2.2 manifolds on the replacement engine. It ran unevenly until I unplugged the varible valve sensors. That appeared to take care of most of the problem except it is now hard to start. Is there a way to make this 2.4 engine work properly in this car; such as changing the head or the electronic engine controls? The dealership said this engine would not work.
redbird is offline
post #2 of 8 (permalink) Old 09-07-2011, 12:58 PM
They ****ed you over. They should've just fixed whatever problem it was that made it overheat. I would bring it back to get your engine fixed or sue them for ****ing your car up
post #3 of 8 (permalink) Old 09-07-2011, 01:24 PM
GpB311's Avatar
Took you a long time to make your first post and its a doozy...
So the mechanic just said "derp derp, 2.4 is close enough to 2.2"?
GpB311 is offline
post #4 of 8 (permalink) Old 09-07-2011, 02:30 PM
BboyTaktix's Avatar
well according to zoomer at ZZP the bottom end of a 2.4 works on most 2.2's or something like that. But in this case I think the guy/mechanic you dealt with didn't know what the hell he was doing. I would definitely take it back and tell them to fix that shiiiit
---------- Post added at 05:30 PM ---------- Previous post was at 05:29 PM ----------
and I'm PRETTTTY sure you need a retune to run a 2.4 engine unless you also swapped the ECU's....and even then....
BboyTaktix
BboyTaktix is offline
post #5 of 8 (permalink) Old 09-07-2011, 03:08 PM
LT1R's Avatar
im pretty sure you could get it to work if you either got a tune or a ecu ment for a 2.4 but other than that the screwed u over and id go have them fix it,and make sure u plug everything back in because then they will say thats the problem and ur still screwed
LT1R is offline
post #6 of 8 (permalink) Old 09-08-2011, 04:19 PM
Nighthawk243's Avatar
Most likely it is still running the tune for the LAP, so it isn't running correctly because of the extra .2l of displacement. Use the LE5 manifold and have Trifecta retune the thing to work properly (Of if you're going to take it back, insist on them getting a custom tune to correct it, as well as using the LE5 mani.)
Nighthawk243 is offline
post #7 of 8 (permalink) Old 09-27-2011, 08:49 PM
hawaii icon
agita_san's Avatar
Moved...
agita_san is offline
post #8 of 8 (permalink) Old 09-28-2011, 05:56 PM
scagnetti76's Avatar
this^
but then to use the 2.2 mani's on the better flowing head. no wonder it runs like ass.
scagnetti76 is offline
