Excessively Slow Shift to Drive - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 16 (permalink) Old 03-09-2012, 04:42 PM Thread Starter
As the title says, I have an excessively slow shift to drive problem.
I thought I'd ask here before I start messing with stuff. I have tested re-tested and tested several more times, I shift into reverse, half way down my drive, I shift into drive, I completely roll into the street before the car finally gets into Drive and starts moving forward, It take roughly about 8 - 12 seconds.
I noticed this a few days back when I would reverse out and go into drive to take off and nothing happened, then finally the car started moving.
So far I assume this could be dirty trans fluid as it does not shift 100% smooth either.
Any idea's anybody?
johnccc is offline
post #2 of 16 (permalink) Old 03-10-2012, 12:38 PM Thread Starter
Last night I did a complete clean out of the Gear stick assembly, completely cleaned it all, it looks nice and new, and moves from gear to gear smoothly, however, there is still a delay, this morning (was cold out) it shifted on time, right when I was showing someone the issue, always the way.. I will do some more testing, hoping it was just something in the interior gear assembly maybe not pulling the cable enough or something.
johnccc is offline
post #3 of 16 (permalink) Old 03-10-2012, 01:35 PM
For safety reasons you can't put car into drive while backing-up over a certain speed. Transmission will only engage in drive after an almost stop.
post #4 of 16 (permalink) Old 03-10-2012, 06:43 PM Thread Starter
Well, here some more news
Not only is it still doing this, now it does not shift from 1 to 2 quickly now, there is a big rev between now. I literally have to drive it like a standard (gas pedal wise).
Something is up for sure...
Dirty trans fluid/filter ?
---------- Post added at 08:43 PM ---------- Previous post was at 07:24 PM ----------
I'm just going to change the fluid and filter, its not a big expense, pretty easy to do too.
I will do this tomorrow, will post back results.
johnccc is offline
post #5 of 16 (permalink) Old 03-10-2012, 07:59 PM
check for leaks too maybe low on fluid cooler lines leak all the time
09 SS/TC 4DR G85
dawkness is offline
post #6 of 16 (permalink) Old 03-10-2012, 08:09 PM Thread Starter
Yea, I will do all that tomorrow when I raise the car up, nothing is on my drive way so I don't suspect any leaks, but still, I will check.
johnccc is offline
post #7 of 16 (permalink) Old 03-10-2012, 08:47 PM
Might want to disconnect battery for a minute or two. Maybe TCM needs a reboot with all the fiddling with ECM.
post #8 of 16 (permalink) Old 03-10-2012, 09:03 PM Thread Starter
I disconnected the battery already, tomorrow I will take it for a test drive, then see how it goes, if its good, I do not go to the auto parts store, if not, well, I do.
Hopefully this and my other sensor issue can be fixed before my LED's come in, it will making modding feel that much sweeter. :D
johnccc is offline
post #9 of 16 (permalink) Old 03-11-2012, 06:04 PM Thread Starter
Did the change, I also had to change the pan since it was so bent it would have taken me all day to straighten it out, so I got a new one, but I got a nice gift with my new pan, it has a drip nut, SCORE!!!!
Anyway, there were no leaks, but it appears there was only about 5 quarts in there, I believe its supposed to be 6.9, so I changed the filter, gasket and pan, added the fluid, took it for a spin and now its working much smoother than before, I no longer have the Shift to Drive delay (bear in mind, its only be tested once, I will post back later if anything changes).
Also, the gear 1 to 2 was a little rough at times, not anymore.
johnccc is offline
post #10 of 16 (permalink) Old 03-12-2012, 01:55 PM
cool! hope that remedies the problem!
sometimes all it takes is a lil maintenance
any idea why the fluid was low if there were no leaks?
sabie is offline
