High RPMs at Overdrive Speed - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 17 (permalink) Old 03-12-2012, 05:43 PM Thread Starter
I have an '07 Cobalt that had been running great until recently. When I'm on the highway at 70 mph or so, my rpms are running around 3200. Until recently, they had been running around 2500. It's like the car won't shift into overdrive, but I've had it into a couple of different shops and both have not been able to find an issue with the transmission. The gas mileage has taken a huge hit (around 32 mpg to 25 mpg). Any ideas?
Copper07 is offline
post #2 of 17 (permalink) Old 03-12-2012, 08:07 PM
It's your torque converter not locking up. Look at TCM or harness. Also if transmission oil is low torque converter will not work. You might also want to verify coolant temperature display to make sure it reads around 190F. If it is low or reads --F (If this circuit is not malfunctioning) torque converter will not work because ECM thinks transmission is too cold.
post #3 of 17 (permalink) Old 03-13-2012, 06:16 AM Thread Starter
One of the shops said the torque converter was locking. Not sure how they knew but assumed they had a way to test that. Haven't really paid attention to the coolant temp. I'm in Minnesota so it might be possible when I'm at highway speed there's enough cold air flow to keep the temp down.
Copper07 is offline
post #4 of 17 (permalink) Old 03-13-2012, 06:24 AM
or reads --F torque converter will not work because ECM thinks transmission is too cold.
It will still lock, even if it says that.
MP81 is offline
post #5 of 17 (permalink) Old 03-13-2012, 07:47 AM
I'm refering to engine coolant temperature sensor not ambient temperature sensor. Coolant temperature has to reach 80C or 175F before Torque Converter lock-up. Of course throttle position and speed are also a factor.
post #6 of 17 (permalink) Old 03-13-2012, 08:05 AM
I'm aware.
Mine doesn't give me a coolant temp reading most of the time. Converter locks up just fine.
MP81 is offline
post #7 of 17 (permalink) Old 03-13-2012, 08:55 AM
Even if your display reading doesn't work it doesn't mean your sensor isn't working. It is one of the criterea for torque lock-up.
post #8 of 17 (permalink) Old 03-13-2012, 08:59 AM
Correct, so they correct thing to say would be make sure your CTS is working, because if the reading is ---*F, it could be working, or could not.
MP81 is offline
post #9 of 17 (permalink) Old 03-13-2012, 09:44 AM
Spliting hairs. Here's the list for TCC lock-up. It could also be the TFT sensor but these are not known to go bad in these transmission. Hope that it's not TFT because transmission has to come apart to change it.
Name:	Auto Trans-1f.jpg
ID:	315   Click image for larger version
Name:	Auto Trans-9.jpg
post #10 of 17 (permalink) Old 03-13-2012, 11:00 AM
Not if thermostat is doing it's job.
