Igntion Lock Cylinder Sticking - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 30 (permalink) Old 04-07-2012, 08:18 AM Thread Starter
stratosproject's Avatar
A few months back, my car was hit while parked. Since that time I have been experiencing intermittent sticking in my ignition lock cylinder.
When I shift the car into park and attempt to key back, the key sticks about halfway into the back turn and gets stuck. The only way to get it keyed all the way back is to wiggle the shifter back and forth while in the park position.
A few of the threads mentioned it may have to do with the shifter micro switch being out of position. Is this a good place to start or has anyone else had/solved the problem? My car is AT.
Thanks in advance for any wisdom.
stratosproject is offline
post #2 of 30 (permalink) Old 04-07-2012, 08:43 AM
No, you need to change the ignition cylinder. Check with sarah, I think there's a silent recall on a series of Cobalts maybe yours is in it.
post #3 of 30 (permalink) Old 04-07-2012, 08:52 AM Thread Starter
Thanks Coby, I'll look into that. I've got a broken hand at the moment, so I'm trying to avoid the usual method of trouble-shooting.
post #4 of 30 (permalink) Old 04-07-2012, 09:24 AM
She ( ChevyCustSvc ) should be on here tuesday, just pm her the last 8 numbers of your VIN in advance with your problem so she knows what to look for because she is going to write.....
Get me the last 8 of your VIN and I can check for recalls.
post #5 of 30 (permalink) Old 04-07-2012, 01:30 PM
Bronxknight28's Avatar
Happened to mine when I went upstate I felt it being stuck, only happened once and then boom my key got stuck! Took it to a Chevy shop and they changed the ignition cylinder for free!
Sent from my PG86100
Bronxknight28 is offline
post #6 of 30 (permalink) Old 04-09-2012, 06:55 AM
As Coby7 stated, I can check for recalls. Hope to talk to you soon!
Sarah
Chevrolet Customer Service
post #7 of 30 (permalink) Old 04-12-2012, 08:22 PM
My wife has a similiar issue in her 05. At first I had to wiggle the shifter to get the key out. Now the door chime NEVER turns off even with the key out. Only turns off when the driver door is closed. Still have the same sticky key issue.
Sarah, Do I need to PM you a VIN or can you check ot from this thread?
Thank you,
Jesse
07 Acura TL- PHD FB 4.1s for kicks,center, rear fill, AF 1.C TW for dash, AF 8.1 for doors, Audiomobile Elite 2208 for rear deck, Pair of FB 12.1, Helix A4 and saving up for more Helix amps and Bitone.
95 Mustang- DVA-7996;H701/C701; Focal Utopia 3-way on PPI PC2150;Morel M428 on PC2100; Boston TypeM SE tweets on PPI PC225; Sub JL 10W6v2 on PPI PC1400 Special Edition
99 Durango IVA-W505; Memphis: 15-MCS6 x2 sets; 15-MC42; 16-XO3; 15-MCP12D4 x2; Powered by Big Belle 1300
splaudiohz is offline
post #8 of 30 (permalink) Old 04-12-2012, 08:40 PM
Don't think the 05s are in the recall. Cylinder is just wore out.
post #9 of 30 (permalink) Old 04-12-2012, 08:48 PM
Well $hit. 37,000 miles and it is wore out. She drives 1.2 miles a day back and forth to work. We have rebuilt the tranny, the tire rods have been replaced as one snapped, brakes failed, had the power steering recall, and now this. Time for a different car.
post #10 of 30 (permalink) Old 04-12-2012, 09:41 PM
Ignition is not wore out by miles it is wore out by how many times you turn the ignition. A new car is going to cost a lot more than a 50$ cylinder that takes 20 minutes to change. 7 years @ lets say twice a day to be conservative is 10,000 times. If she goes out for lunch double that if she takes the car out again once at night double that again. It accumulates and wears. Did you spray light oil in the cylinder once in a while? Regular maintenance, see owners manual.
