Battery Voltage Idling at 16 Volts? - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 6 (permalink) Old 06-16-2012, 09:46 PM Thread Starter
Alright so i've had my balt for around 2 months. Its a base model with the 2.2, has about 129k on it. Over the past few days i've been monitoring the voltage on my multi-meter. Sometimes it sits just over 12 volts, sometimes it will run at 14.4 ish(which i thought all stock cars would idle around) and sometimes my voltage will start off at 15 volts and work up to 16 volts sometimes. I checked out a different forum, and someone had the same problem and people were suggesting the voltage regulator is probably bad? I found it sort of weird being a stock alt. and it was charging up so high. but I was just curious to if anyone else has had this happen to them, and if so how did they fix it?
Thanks!
Lamothe is offline
post #2 of 6 (permalink) Old 06-16-2012, 10:14 PM
You must be burning bulbs. Only way to fix that is to change the alternator. Battery charging voltage should never exceed 14.5 volts, 14.3 being nominal. @ 16 volts something is going to give....
post #3 of 6 (permalink) Old 06-17-2012, 06:57 AM
yea sounds like the regulator bit the dust.
post #4 of 6 (permalink) Old 06-17-2012, 05:17 PM Thread Starter
well, nothings burnt out - so far haha. but it will only run at 16 volts like 1 in 4 start-ups, otherwise it runs between 12 and 14, anyways thanks for the feed back
Lamothe is offline
post #5 of 6 (permalink) Old 06-17-2012, 05:58 PM
Signs of things to look forward too.
post #6 of 6 (permalink) Old 06-18-2012, 06:58 PM
you should change it before it gets worse, if voltage starts to go up you can fry electrical equipment
16 volts idling , battery voltage
