Codes P1818 and P0700 - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 5 (permalink) Old 07-09-2012, 12:29 PM Thread Starter
Exclamation Codes P1818 and P0700
Hey everyone. My car has been driving fine, but then 2 days ago my check engine light came on. I read the codes and they came up p1818 and p0700. So I googled them, and P1818 - Transmission Neutral Safety Switch Short Circuit To Battery and the other one is pretty much saying that there is a code (so it's a code for a code). Sooo the big question(s) is/are...
Can I fix this without taking it to the garage?
If so, what could I do?
I'm just not sure what I could do to try and find the problem with it.
Any suggestions would be great.
Thanks.
chevygirl0591 is offline
post #2 of 5 (permalink) Old 07-09-2012, 01:12 PM
Well you can start by giving us more info, year,engine,transmission would be nice for starters. DTC codes are all listed on this site for our cars.
https://www.yourcobalt.com/forums/pro...-cel-list.html
---------- Post added at 04:12 PM ---------- Previous post was at 04:09 PM ----------
P0700 Transmission Control System Malfunction
P1818 Transmission Fluid Pressure (TFP) Valve Position Switch Indicates Drive without Drive Ratio -TCM"
So obviously it is an automatic.
post #3 of 5 (permalink) Old 07-09-2012, 01:17 PM Thread Starter
2005
2.2 ecotec, automatic...
post #4 of 5 (permalink) Old 07-09-2012, 01:23 PM
P1818 The TCM detects a PARK, NEUTRAL, or a drive range with a REVERSE ratio for 3 seconds.
This means this code could be set by putting your car in drive while it is still backing up. Always bring your car to a stop before shifting to drive. It could also be set coasting down a hill or driveway backwards in neutral for more than 3 seconds.
I would clear the code and see if it does it again in normal driving.
post #5 of 5 (permalink) Old 07-09-2012, 04:00 PM Thread Starter
I hardly ever shift without stopping completely. I'll give it a try, and I hope it works. I'll keep things posted. Thanks.
