Temp Guage Not Working - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 13 (permalink) Old 07-09-2012, 02:35 PM Thread Starter
just replaced the temp sending unit and still not working ( second one ) . this started last winter . would work some times and then stop . when not working the eng. fan keeps running . twice the check eng. light came on . just happened again 2day .. replaced sending unit and worked for a week , now not working . code said , sending unit , low coolent , stuck thermostat .. checked temp and ok ?? thanks for all your help .. one tech said the computer might be on it's way out ... 2007 .......
valkerie is offline
post #2 of 13 (permalink) Old 07-09-2012, 02:40 PM
What were the codes exactly? When it worked did it read properly or was it reading low?
post #3 of 13 (permalink) Old 07-09-2012, 02:43 PM
What kind of coolant are you putting in?
post #4 of 13 (permalink) Old 07-09-2012, 06:29 PM Thread Starter
temp guage
coolant was replaced when cyl. head was replaced by dealer 16 months ago .
never had a problem with temp ... maxed out @ 217 in summer traffic then came right down .. as far as the code , I went to auto zone for a reading , can't stand dealers .. went there just for warrenty work .. again thanks ..
valkerie is offline
post #5 of 13 (permalink) Old 07-09-2012, 06:46 PM
They tell you what dtc it was?
post #6 of 13 (permalink) Old 07-10-2012, 05:41 AM
Thermostat.
Had the same exact problem for a while. Replaced the thermostat a few months ago and have had no such issue.
MP81 is offline
post #7 of 13 (permalink) Old 07-10-2012, 04:05 PM Thread Starter
temp guage
code p0128 came up ...some say the thermostat
valkerie is offline
post #8 of 13 (permalink) Old 07-10-2012, 04:40 PM
Exactly what MP81 says. P0128 is set when engine coolant does not reach intended temperatures in a preset timelaps. This is caused by a weak spring in the thermostat or deteriorated seal causing coolant to bypass upon warm up. So yes, change the thermostat, not a big job if nothing is seized.
post #9 of 13 (permalink) Old 07-11-2012, 05:39 AM
Exactly what MP81 says. P0128 is set when engine coolant does not reach intended temperatures in a preset timelaps. This is caused by a weak spring in the thermostat causing coolant to bypass upon warm up. So yes change the thermostat, not a big job if nothing is seized.
Yup. Actually, it may also be like mine - there is a rubber portion that covers a bunch of 1/4" holes around the main part - that rubber had broken apart allowing coolant to freely flow right through. Both caused the problem of coolant bypass though, and replacing it was a mighty good idea.
But yup, rather easy to change I thought.
MP81 is offline
post #10 of 13 (permalink) Old 07-13-2012, 12:42 PM Thread Starter
temp guage
getting the thermostat changed on monday ... thanks and will let you know the results ...........
valkerie is offline
