'05 Cobalt Lock Problem - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 12 (permalink) Old 07-15-2012, 02:08 PM Thread Starter
Hello all, we have an '05 Balt with a laundry list of issues (correction-it has subscriptions of issues). As of yesterday the locks have developed a mind of their own. Here are the signs we are working with:
When the car is locked with remote-The car unlocks itself again.
When the car is placed into Drive-The locks engage, but then unlock again.
NONE of the UNLock buttons work, however the Lock buttons work fine.
Looking for any suggestions on this issue.
Thanks!
Jesse
07 Acura TL- PHD FB 4.1s for kicks,center, rear fill, AF 1.C TW for dash, AF 8.1 for doors, Audiomobile Elite 2208 for rear deck, Pair of FB 12.1, Helix A4 and saving up for more Helix amps and Bitone.
95 Mustang- DVA-7996;H701/C701; Focal Utopia 3-way on PPI PC2150;Morel M428 on PC2100; Boston TypeM SE tweets on PPI PC225; Sub JL 10W6v2 on PPI PC1400 Special Edition
99 Durango IVA-W505; Memphis: 15-MCS6 x2 sets; 15-MC42; 16-XO3; 15-MCP12D4 x2; Powered by Big Belle 1300
splaudiohz is offline
post #2 of 12 (permalink) Old 07-15-2012, 02:25 PM
Kinda looks like you have a bad unlock switch that is stuck closed. Did you happen to leave a window open in a downpour?
post #3 of 12 (permalink) Old 07-15-2012, 03:11 PM Thread Starter
No, but the manual windows do not stay shut in the car. They work their way down after a few miles of driving.
How to I check/replace this part?
Thank you Coby for the quick response.
post #4 of 12 (permalink) Old 07-15-2012, 03:55 PM
I would start by wiggling and playing with the unlock switch drivers door since it is the one used the most. If that don't help, take the switch apart and measure for continuity.
---------- Post added at 06:55 PM ---------- Previous post was at 06:54 PM ----------
Oh, have you tried your other remote and keeping the regular one at a distance in case it is your remote.
post #5 of 12 (permalink) Old 07-15-2012, 04:16 PM Thread Starter
I will pull that thing out tonight and toss a dmm on the car and switch.
I have tried the remote removal. That is a good call btw. Not many think of that one.
post #6 of 12 (permalink) Old 07-15-2012, 04:24 PM
Yeah, sometimes when the battery goes low remotes will start to have a mind of their own.
post #7 of 12 (permalink) Old 08-02-2012, 03:42 PM Thread Starter
I noticed her driver side lock is no longer illuminated. Would a simple switch replacement remedy this problem, or is the problem deeper?
post #8 of 12 (permalink) Old 08-02-2012, 05:10 PM
I think acoutu has taken these apart, he might know if you can just change the bulb.
---------- Post added at 08:10 PM ---------- Previous post was at 08:05 PM ----------
Have you tried repositioning the handle at 10 o'clock as oppose to 2 o'clock maybe, on the drivers side when window is fully up. The shear little downward pressure by the handle might keep your window up. I don't think the handle is keyed for one spot in particular.
post #9 of 12 (permalink) Old 08-02-2012, 08:23 PM Thread Starter
There is still the issue of the UNLOCK not working and the car unlocking itself when the LOCK is hit.
post #10 of 12 (permalink) Old 08-02-2012, 08:48 PM
The switches are easily replaced. Swapping the bulb is difficult due to the limited space in the switch, but its still possible with a bit of patience. the switch very well may be causing the problem though
as for the unlock, it definitely sounds like something is stuck and constantly sending the unlock signal. have you tried to manually locking the doors to see if they pop open again?
acoutu is offline
