PO036 & PO141 Codes - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 5 (permalink) Old 07-16-2012, 06:46 PM Thread Starter
PO036 & PO141 Codes
I pulled these codes PO036 & PO141 off my 2005 cobalt. Any clue what causes this and what need replaced. Thanks for any info you can give me.
johnjr1266 is offline
post #2 of 5 (permalink) Old 07-16-2012, 07:19 PM
Looks like your downstream HO2 sensor has bit the dust. Check fuse but first HO2 would have set codes also. Check for broken wires first, but my guess is you need an HO2 sensor.
P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)
P0141 Oxygen Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
DTC P0141
Circuit Description
Heated oxygen sensors (HO2S) are used for fuel control and post catalyst monitoring. Each HO2S compares the oxygen content of the surrounding air with the oxygen content in the exhaust stream. The HO2S must reach operating temperature to provide an accurate voltage signal. A heating element inside the HO2S minimizes the time required for the sensor to reach operating temperature. Voltage is provided to the heater by the ignition 1 voltage circuit through a fuse. With the engine running, ground is provided to the heater by the HO2S heater low control circuit, through a low side driver within the powertrain control module (PCM). The PCM commands the heater ON or OFF to maintain a specific HO2S operating temperature range. The PCM determines the temperature by measuring the current flow through the heater and calculating the resistance. Based on the resistance, the PCM can predict the sensor temperature. For diagnosis, the PCM monitors the heater current with the engine running. The PCM also calculates the heater resistance on a cold start. Both diagnostics will only run once per ignition cycle. If the PCM detects that the heater current or the heater calculated resistance is not within an expected range, DTC P0141 sets.
post #3 of 5 (permalink) Old 07-16-2012, 07:23 PM Thread Starter
Thanks...Thats the one after the converter? there are only two correct?
---------- Post added at 09:23 PM ---------- Previous post was at 09:20 PM ----------
Last question. Is there a certain brand I should get or does it not matter. Thanks again.
post #4 of 5 (permalink) Old 07-16-2012, 07:30 PM
Yes only 2 and yes the downstream is the one after the converter.
AC Delco or OEM, people on here have had difficulties with bosch.
post #5 of 5 (permalink) Old 07-16-2012, 07:32 PM Thread Starter
Thanks
