Steering Rack Acting Up Now - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 7 (permalink) Old 07-25-2012, 05:14 PM Thread Starter
I brought my 2006 Cobalt back to the mechanic who replaced my struts because my car is wandering and has been pulling to the left, also feels loose.
They tested everything, disconnected steering linkage components to check for binding, checked alignment and tires etc.
They tried to check the steering position sensor but they said their scope was blocked from reading the info.
Their conclusion was that the steering rack needs to be replaced. Damn it! My car really started acting up after the power steering motor recall and the intermediate shaft had to be replaced for the second time. Now this.
These problems should not be cropping up continually and GM should have extended our warranties because they know all about the faulty steering and front end components in our cars.
I'm afraid to find out how much this is going to cost me. If GM wants me to keep buying their products they really need to step up and help us out.
steve333 is offline
post #2 of 7 (permalink) Old 07-26-2012, 06:49 AM
i944scania's Avatar
check bushings, how hard is it pulling on the highway? unlikely the rack needs to be replaced
07 LSJ turbo swap
-to4e 50 trim .63 a/r @ 19psi
-2.5" exhaust
-3" intake
-siemens #60s
-aem uego wideband afr
-HP custom tune
i944scania is offline
post #3 of 7 (permalink) Old 07-26-2012, 01:27 PM Thread Starter
It's pulling to the left mainly but also wandering. It doesn't feel dangerous, yet, but it makes it hard to drive comfortably.
steve333 is offline
post #4 of 7 (permalink) Old 07-26-2012, 01:48 PM
Doesn't really sound like the steering rack. More like someone aligned your car incorrectly or didn't at all.
post #5 of 7 (permalink) Old 07-26-2012, 02:08 PM Thread Starter
Nope, they checked the alignment and rotated the tires to make sure it wasn't a tire issue
steve333 is offline
post #6 of 7 (permalink) Old 07-26-2012, 02:14 PM
Wandering is usually caused by inner tie rods. Tie rods wear on all vehicles. Inner tie rods come with a new or refurbish steering rack no matter what route you take. Maybe a 2 hour job if you don't know what your doing. If your rack is good you can just change inner tie rods.
post #7 of 7 (permalink) Old 07-26-2012, 02:19 PM Thread Starter
They said they checked the tie rods. So if I get the steering rack replaced it will come with new inner tie rods?
Signs of a bad steering rack
Car Wandering
If your car is wandering on the road, both at low speeds and high speeds, it’s a sign that the steering rack has gone bad. You’ll need to constantly correct the direction. However, the alignment will appear fine and there will be no excessive wear on the tires
Numb Spot
With a bad steering rack there will tend to be a so-called “numb spot” in the center of the steering. Between about 11 o’clock and 1 o’clock there might be little response, which can be a certain indication that there are steering rack problems.
Wheel Shaking
If the steering wheel shakes when moving at higher speeds, couple with too much play in the wheel, the steering rack has probably gone bad and needs to be replaced. Apart from anything else, the lack of control with a wheel shaking can prove to be dangerous, especially on freeways.
Power Steering Fluid
If your power steering fluid keeps going down, even after adding more, then it’s time to have the steering rack replaced. Check fluid levels regularly.
steve333 is offline
