Highbeams Not Working - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 5 (permalink) Old 07-27-2012, 05:28 PM Thread Starter
Post Highbeams Not Working
So the other night my drivers side headlight went out, but i still had highbeams. I went to canadian tire and bought a new 9007 bulb and installed it. After installation my lows and daytime running lights work but i now have no highbeams at all, also the indicator light on the dash doesnt come on anymore. I have checked the fuses and they are fine but i cant figure out why i have no highs. This is on an '06 cobalt lt. Any ideas??
NLoek is offline
post #2 of 5 (permalink) Old 07-27-2012, 07:36 PM
Well this is odd. Each headlight filament is fused seperately, so pretty much unrealistic to think it would be the fuses if both lights don't work. Did you jumper low and high fuses to make sure your bulb filaments work? Only common thing between the 2 highbeams is the highbeam relay. But the highbeam relay is turn on at the same time as the blue icon lamp in the intrument panel via a different route mind you but by the same logic. BCM turns highbeams on and off when it gets the signal from the headlight lever.
Mmmmm, does your flash to pass (Optical Horn) work?
---------- Post added at 11:36 PM ---------- Previous post was at 09:59 PM ----------
In case it wasn't clear. With car off, jumper from boost post to any of the four headlight fuses. Each fuse will light a different filament in the headlight. So have a friend stand in front and you can check if all filaments are good. You have to start somewhere. Maybe this picture will help.
post #3 of 5 (permalink) Old 07-28-2012, 12:29 PM Thread Starter
I'll give it a try.
NLoek is offline
post #4 of 5 (permalink) Old 07-30-2012, 06:12 AM
i944scania's Avatar
check that youve got the right blub
07 LSJ turbo swap
-to4e 50 trim .63 a/r @ 19psi
-2.5" exhaust
-3" intake
-siemens #60s
-aem uego wideband afr
-HP custom tune
i944scania is offline
post #5 of 5 (permalink) Old 07-30-2012, 06:59 AM
Different bulb would be keyed differently and not fit the socket, plus he said he bought 9007.
