Rpm Idle Problem - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 26 (permalink) Old 08-07-2012, 05:23 PM Thread Starter
Exclamation Rpm Idle Problem
Hey guys ! sorry if i write things not well im a french guy lol
My chevy cobalt 2005 ls have a problem and i dont know what it is when i brake at a stop or a red light my RPM IDLE goes up and down a couple of times before it stabilize
it feels like the exaust push more air
Thanks if you can help me with that
BigBossVinny is offline
post #2 of 26 (permalink) Old 08-07-2012, 05:28 PM
Does it do it all the time or only with the ac or heater on?
post #3 of 26 (permalink) Old 08-07-2012, 05:41 PM Thread Starter
all the time .....
post #4 of 26 (permalink) Old 08-07-2012, 06:37 PM
My buddy JUST had the SAME EXACT problems you are describing. It ended up being (and someone please correct the poor terminology) the Idle Control Sensor (maybe Module). I never heard of it. It was not cheap to replace, but it took care of the issue.
07 Acura TL- PHD FB 4.1s for kicks,center, rear fill, AF 1.C TW for dash, AF 8.1 for doors, Audiomobile Elite 2208 for rear deck, Pair of FB 12.1, Helix A4 and saving up for more Helix amps and Bitone.
95 Mustang- DVA-7996;H701/C701; Focal Utopia 3-way on PPI PC2150;Morel M428 on PC2100; Boston TypeM SE tweets on PPI PC225; Sub JL 10W6v2 on PPI PC1400 Special Edition
99 Durango IVA-W505; Memphis: 15-MCS6 x2 sets; 15-MC42; 16-XO3; 15-MCP12D4 x2; Powered by Big Belle 1300
splaudiohz is offline
post #5 of 26 (permalink) Old 08-07-2012, 07:17 PM
Bienvenue mon ami. I would clean throttle body first if it doesn't stall and you have no codes. Cheaper things first.
post #6 of 26 (permalink) Old 08-07-2012, 07:37 PM Thread Starter
how much will it cost me if its the sensor etc ?and when i drive at night when i stop at a light behind an other car its like my light loosin a bit of power for a second ...
post #7 of 26 (permalink) Old 08-07-2012, 07:44 PM
I doubt it your sensor if you don't have a check engine light.
Get your throttle body and butterfly cleaned if you don't know how. Most garages charge like $20 to do this. Then you worry about sensors if it still runs bad. My experience tells me it's never been cleaned and this is your problem. The reason your lights are dimming is because the alternator speed falls below the charge threshole and your battery voltage falls from 14.3 to 12 volts which is normal if RPMs fall under 700.
post #8 of 26 (permalink) Old 08-07-2012, 07:58 PM Thread Starter
if i clean the throttle body and the butterfly the problem with the light going to be ok or its an other problem to check ?
post #9 of 26 (permalink) Old 08-07-2012, 08:08 PM
If cleaning the throttle body settles your RPM fluctuations your lights will not dim anymore. One is dependant on the other.
post #10 of 26 (permalink) Old 08-07-2012, 08:34 PM Thread Starter
thanks im going too check it out and give you news !!
