Headlights - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 12 (permalink) Old 08-13-2012, 01:15 AM Thread Starter
ingram_22's Avatar
Headlights
So my pass headlight only works if the high beam is on. I replaced the bulb and the fuse for it. And one have any ideas
ingram_22 is offline
post #2 of 12 (permalink) Old 08-13-2012, 04:42 AM
What year ?
post #3 of 12 (permalink) Old 08-13-2012, 04:50 AM Thread Starter
ingram_22's Avatar
2005
post #4 of 12 (permalink) Old 08-13-2012, 06:48 AM
I have plenty of ideas, might need a friend to help out though. Did you remove the headlamp assembly completely to change the bulb? If so one of the connector pins might have pushed out. Bulb is 9007 just in case. If everything is fine there with car off jumper from boost post to low beam fuse (little metal tab on top. This will test path to ground and verify;bulb to ground,filament,fuse and wire feed to low beam.
post #5 of 12 (permalink) Old 08-13-2012, 09:46 AM Thread Starter
ingram_22's Avatar
Yea I but two brand new bulbs in there last night.
post #6 of 12 (permalink) Old 08-13-2012, 09:48 AM Thread Starter
ingram_22's Avatar
How do I do the jump thing with the fuse
post #7 of 12 (permalink) Old 08-13-2012, 10:02 AM
one side of the wire to the booster pillar, the other side to the fuse (theres two small exposed spots on top of the fuse, use that as a contact point)
It SHOULD turn on the lights, but when we hear back from you it will be easier to proceed.
Does the DRL light work as well? Try this same thing with that fuse as well.
acoutu is offline
post #8 of 12 (permalink) Old 08-13-2012, 01:17 PM Thread Starter
ingram_22's Avatar
Can someone show me how to do this so I don't mess up.
post #9 of 12 (permalink) Old 08-13-2012, 01:35 PM
A picture is worth a thousand words.
Try not to touch any other fuses than the 5 headlamp fuses. They are all red 10 amp fuses.
---------- Post added at 05:35 PM ---------- Previous post was at 05:18 PM ----------
Have somebody stand in front, to check if your lights work. The "DRL" fuse will light both amber lights at same time on 05-06. Both low beams on 07up. 4 other fuses light each filament individually. They are clearly marked on bottom of cover.
Here just to be safe...
Be careful with the tip of that wire it has unfused B+.
To help you anymore I'd have to fly down.
post #10 of 12 (permalink) Old 08-13-2012, 05:08 PM Thread Starter
ingram_22's Avatar
Thanks man. My drl lights work its just the low beam itself.
