09 Cobalt LS Automatic Hard Shift - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 16 (permalink) Old 08-24-2012, 10:23 AM Thread Starter
Hi all,
I'm new to this forum and in in need of some help.
my 2009 cobalt (LS 4 door) started shifting hard from 1st gear to 2nd. this only happens when I'm at a stopped light and drive off and when it shifts from 1st to 2nd it shifts hard that the you can feel the pull.
any advise what could it be. I would really appreciate.
its my daily driver car and its automatic transmission. the car has 176xxx miles. i just hope my transmission its not going out.
Thanks
09cobaltls is offline
post #2 of 16 (permalink) Old 08-24-2012, 10:38 AM
When did you flush the tranny fluid and replace the filter?
post #3 of 16 (permalink) Old 08-24-2012, 10:49 AM Thread Starter
it has never been done to my knowledge.
the dealer says it has a sealed transmission therefore the transmission fluid is lifetime.
post #4 of 16 (permalink) Old 08-24-2012, 10:55 AM
Your dealer is a dumb a$$
---------- Post added at 12:55 PM ---------- Previous post was at 12:55 PM ----------
I'll bet you are a quart or two low
post #5 of 16 (permalink) Old 08-24-2012, 11:00 AM Thread Starter
can i just add the quart myself or will i have to take it to the dealer.
i know the fill hole has a cap. do i just remove it and try to put the fluid in there?
or are there any specials tools needed??
thanks
post #6 of 16 (permalink) Old 08-24-2012, 11:03 AM
Where do you think there is a fill cap for your tranny fluid? I've never seen an auto?
post #7 of 16 (permalink) Old 08-24-2012, 11:06 AM
That is a vent cap, hold on let me find the thread for checking your fluid. Pretty sure that's not your problem though.
https://www.yourcobalt.com/forums/tra...08-cobalt.html
Did you check the "TCM" fuse? Pull it out of the slot to check it if it's good, check tabs for corrosion, flip 180 and re-install. If this doesn't solve it check the "TCM" ground strap (G105) on the transmission case front of engine.
post #8 of 16 (permalink) Old 08-24-2012, 11:50 AM Thread Starter
ok thanks ill do this today when i get home.ill check the TCM fuse. i hope this solves my problem
post #9 of 16 (permalink) Old 08-24-2012, 12:04 PM
Any DTCs? No DTCs means it isn't engine related, like sensors and such.
post #10 of 16 (permalink) Old 08-24-2012, 12:07 PM Thread Starter
nope the car has no codes no lights.
except the TPMS light because it has after market wheels
