2009 Colbalt LS Wont Start, No Power - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 28 (permalink) Old 08-29-2012, 03:00 PM Thread Starter
Went to start my car today and i had no power, no nothing key is now stuck in car and a jump did nothing, not even powered anything on. can i please get some help with my issue.
cavalierz2 is offline
post #2 of 28 (permalink) Old 08-29-2012, 03:14 PM
Sounds like your alternator is dead.
post #3 of 28 (permalink) Old 08-29-2012, 03:23 PM Thread Starter
How could it be alternator, if it wont even power up when connected for a jump start?,
I think that my sister lefts the head lights on yesterday during the day after driving through a construction zone
post #4 of 28 (permalink) Old 08-29-2012, 03:33 PM
Have you had the battery checked?
post #5 of 28 (permalink) Old 08-29-2012, 04:35 PM
Bronxknight28's Avatar
Check battery post in the trunk? Make sure they are tight!
Sent from my PG86100
Bronxknight28 is offline
post #6 of 28 (permalink) Old 08-29-2012, 04:37 PM Thread Starter
No i did not check the battery since its in the trunk, and no spare key, had to call GM Services and they came out tried to jump it again and same results to they towed it to the dealership.
post #7 of 28 (permalink) Old 08-29-2012, 04:53 PM
OK, why can't you open the trunk again?
You can't forget lights on with a Cobalt, they turn off automatically after 10-12 minutes, even if you turn them on after you take the key out of the ignition.
If you don't even have a dome light, this means it's your battery, battery connections or "BCM" fuse. If you have dome and radio then it could probably be your run crank fuse or Boost post has come loose.
If your key is stuck in the ignition because you have no power, you can insert a pin under the steering wheel to release the key from cylinder.
post #8 of 28 (permalink) Old 08-29-2012, 05:13 PM Thread Starter
I have no power at all what so ever, it was not on automatic lights, it was on manual lights. And thanks for the tip on the key
post #9 of 28 (permalink) Old 08-29-2012, 05:20 PM
Don't matter if it's on manual it will shut off after 10 or 12 minutes.
You said a jump did nothing, then you probably have a burnt "BCM" fuse. Would the lights come on? If even the lights wouldn't come then you have a really dead battery.
I would get an extra key cut just to open doors and trunk, this key doesn't have to be a pass-lock and you just won't be able to start the car with that particular key.
post #10 of 28 (permalink) Old 08-29-2012, 05:29 PM Thread Starter
Yeah not a thing will power on
