"CES" Light on but Cant Pull Codes??? - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 54 (permalink) Old 08-31-2012, 12:52 PM Thread Starter
Hello, This is my first post but not my first problem w/ this Cobalt. I start the car and the CES and TC light are on and POWER STEERING is displayed on the cluster. The electric assist steering is inop and I also notice the tach needle twitching while engine is running. The park brake indicator light flickers as well as the DRL's. I attempt to drive the car and the trans shifts very hard and prematurely shifts into OD so the car lugs.
I attempt to pull codes w/ my scanner and communcation link failure is shown. I borrow another scan tool with the same end result. I cant seem to communicate w/ the PCM...
-All fuses check good (w/ test light)
-Have power on pin 16 at DLC and ground at pins 4 and 5 at DLC
One question that I have is: Do all these problems share a common ground that could be loose?
I have looked at all the TSB's I can find and nothing matches.
I have read of come corrosion issues at the UHFB but nothing official.
I know there are some very sharp techs on here and I thank you in advance for any help.
Ben
1972cst is offline
post #2 of 54 (permalink) Old 08-31-2012, 01:58 PM
What year? Bet it's a pre 07.
post #3 of 54 (permalink) Old 08-31-2012, 02:28 PM Thread Starter
Im sorry, I should have been more thorough... this thing has made me a little !
2006 Cobalt 2.2 auto
1972cst is offline
post #4 of 54 (permalink) Old 08-31-2012, 03:05 PM
OK, makes sense now because an 07 up would not run with Open "ECM" ground. 05-06 ignition module is seperate from "PCM" which is the reason yours even starts. You probably have an open "PCM" ground.(G105) this would make all your present failures make sense. G105 is on the transmission case just as it butts to the engine block visible in the front. G103 is bolted to the sub frame below drivers side headlight or ABS module if you have one. I've posted G107 but ignore it for your problem.
If you lose your "PCM" ground you can't pull codes because OBDII as lost it's signal path.
---------- Post added at 07:05 PM ---------- Previous post was at 06:54 PM ----------
For trouble shooting try grounding the "PCM" case to see if symptoms disappear.
post #5 of 54 (permalink) Old 08-31-2012, 06:43 PM
Any more questions? Might have forgotten something.
post #6 of 54 (permalink) Old 08-31-2012, 08:20 PM Thread Starter
Just one more question Coby... how do you do that?????
Your knowledge on this information baffles me! You must work in tech support or something.
I will try to supply a temporary ground to the ECM for testing purposes. Where is the ECM exactly? There are two modules mounted in front of the underhood fuse block. I think the big one is what Im looking for???
1972cst is offline
post #7 of 54 (permalink) Old 08-31-2012, 08:31 PM
HerBalt's Avatar
The one the cover clips on to. a quick way to check if its the ecm ground is to run a wire right to the metal shell of it to a known ground. Just tape it (temporarily obviously) and start the car. if it all goes away, thats your culprit. If not, double check your new ground before moving on to more trouble shooting.
Coby7 is an amazing asset to this site!
HerBalt is offline
post #8 of 54 (permalink) Old 08-31-2012, 09:00 PM Thread Starter
Ok just tried grounding the ECM case to a known ground w/ alligator clip jumper wire and nothing changed. All problems still present, cant communicate w/ scan tool either.
1972cst is offline
post #9 of 54 (permalink) Old 08-31-2012, 09:55 PM
try the same thing as above with the PCM. I dont know if its a metal case or not.
You could always check the actual ground connection as well, but if its insulated wire you may not see a break in the circuit, so that grounding trick will tell you if the PCM is indeed the culprit without having to replace the whole ground path.
acoutu is offline
post #10 of 54 (permalink) Old 09-01-2012, 05:15 AM
"PCM" case on a 2006 will all be oxidized. Make sure you clean the spot you ground to. Same with chassis ground you use. "PCM" is the module with two connectors, the one closest to fuse block.
---------- Post added at 09:15 AM ---------- Previous post was at 07:56 AM ----------
Hope this works because the other option is that your "PCM" processor has failed. Also a possibility, but the flickering headlights kinda point to a bad ground. Your sure you check the "PCM" fuse. Pull it out and re-insert to make sure the contacts are clean.
