Interesting Turn Signal Question - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 9 (permalink) Old 09-16-2012, 08:54 PM Thread Starter
Lightbulb Interesting Turn Signal Question
So, I recently noticed that my driver's side turn signal light in the front is always half-way on. The head-on turn signal and the side signal are both on (when running lights are auto on). Now, the blinker still WORKS. It starts blinking normal brightness, then falls back to the "always on" that isn't normal, but the lights stay solid the whole time. I've tried switching the bulbs from left to right and checked that all filaments are in-tact. Doesn't seem to be a wiring issue, either. The back break lights and turn signals work just fine. It's a 2008 LT2 sedan... anyone have any ideas? Thanks!!
mirbalt is offline
post #2 of 9 (permalink) Old 09-16-2012, 11:02 PM
Check to see if your DRL loop has melted through the harness and now touching that particular wire. Mine did.
post #3 of 9 (permalink) Old 09-17-2012, 08:17 AM
Good morning mirbalt,
Looks like you've gotten some superb advice from Coby7 - hope you're able to find the root of the problem! If you end up deciding that you'd like to visit your dealership, keep me updated on how everything goes as I'm available to assist in whatever ways I can.
Sarah, GM Customer Service
post #4 of 9 (permalink) Old 09-17-2012, 01:06 PM
If it looks like this chances are that blinker wire is touching DRL wire.
post #5 of 9 (permalink) Old 09-17-2012, 03:23 PM
Here's where I opened mine o find the mess about center of rad support. DRL voltage is about 8volts which would explain the dim lit blinker bulb.
post #6 of 9 (permalink) Old 09-19-2012, 07:45 PM Thread Starter
Thanks for the photos, Coby7. Where abouts is this in terms of... well... the rest of the car?
mirbalt is offline
post #7 of 9 (permalink) Old 09-20-2012, 02:56 AM
Right along the inside of radiator support on top of fan shroud.
post #8 of 9 (permalink) Old 09-20-2012, 10:13 PM Thread Starter
Great! Thanks again. I'll take a look in the morning.
mirbalt is offline
post #9 of 9 (permalink) Old 09-21-2012, 03:28 AM
Just cut a little slit in the black tape covering the plastic armour and check for a purple wire. If you find it that means the DRL wire didn't burn. But if you find the same mess I did take your time and isolate each wire. Clean it up and replace defective wires. Then wrap DRL wires seperately in a different armour.
bulb , electrical , headlight , turn signal
