Ignition Switch - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 4 (permalink) Old 09-22-2012, 12:49 PM Thread Starter
Ignition Switch
could this be an ignition switch going bad.....? i can turn the key and try and start the car. the starter cranks but i have no ignition.
if it is where and how do i change it?
silveradoboy
2006 RCSB Chevy Silverado 2wd (mine)
2007 Cobalt Coupe LS (wifes)
silveradoboy is offline
post #2 of 4 (permalink) Old 09-22-2012, 01:48 PM
That could be anything from your battery to your spark plugs to your coil packs, fuel injectors, check your fuses for anything pertaining to that, it sounds like a dead battery or you blew a fuse to your fuel pump or coil packs or something, just check out that stuff and if not then get it towed to a shop
Sent from my Autoguide iPhone app
K&N 69 series typhoon CAI, D2 2" lowering springs, de-badged rear, front black chevy bow tie, halo projector headlights, borla catback with a resonator delete, ss turbo recaro seats, swapped black interior, custom painted interior trim
Base Balt is offline
post #3 of 4 (permalink) Old 09-22-2012, 01:56 PM Thread Starter
ive replaced the battery and starter and i just replaced the fuel filter. it only happens intermitenly.
fuel pressure at the fuel rail is 50 psi
silveradoboy
post #4 of 4 (permalink) Old 09-22-2012, 01:58 PM
Ignition 1 fuse underhood
---------- Post added at 04:58 PM ---------- Previous post was at 04:56 PM ----------
Intermittent? Different story but I would still pull the fuse flip 180 and re-insert in case it has developped corrosion.
