06 Shutting Off - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 8 (permalink) Old 09-23-2012, 07:17 AM Thread Starter
06 Shutting Off
Hi. New to the forumn. I have an 06. About 48000 miles. Very well taken care of. A few days ago it just started shutting off when making a corner from a light or stop sign. Or coming to a stop down a steep hill. I thought maybe a fuel filter cuz it happened after a low fuel run and refill. So I replaced that, But it is still doing it a few days later? I googled it and it appears to be happening to other cars but I haven't found any answers to why. No CEL. Seems to run fine otherwise????? Thx
Samiam1017 is offline
post #2 of 8 (permalink) Old 09-23-2012, 08:47 AM
Is your radio staying on when engine dies?
post #3 of 8 (permalink) Old 09-23-2012, 09:20 AM Thread Starter
Ok just went out for a test drive. It's starting to do it even in a straight line. ( no corner or hill). This is only at slow speeds. Everything shuts down like a electrical shut down. The radio does go out as do all the dash lights and gauges. I checked the battery connections. All clean and tight. I think I may run it down and get it load tested just to eliminate that. ? I think this is getting dangerous to drive at this point.
post #4 of 8 (permalink) Old 09-23-2012, 10:14 AM
Check your boost post on the fuseblock to make sure it's tight.
post #5 of 8 (permalink) Old 09-23-2012, 05:46 PM Thread Starter
Well I went to advanced auto. They checked the condition of the battery. Was in excellent condition as was the charging system. They recommended cleaning maf and throttle body. So i bought the stuff I needed. Drove around for 20 min and the problem wasn't happening. So I cleaned them up anyway and checked all the connections at the fuse box and battery again. I guess it's a waiting game to see if the problems still there. But I will post again either way for everybody's future reference. Thx
post #6 of 8 (permalink) Old 09-23-2012, 05:55 PM
Did you touch the boost post at all? Because if it was just a tad loose and you moved it your problem will disappear for a while until corrsion sets in again.
post #7 of 8 (permalink) Old 09-23-2012, 07:47 PM Thread Starter
That was tight. Dont really think that was it but I'll check again when the problem starts again. Thx coby
post #8 of 8 (permalink) Old 09-23-2012, 08:03 PM
Why don't you just loosen it and screw it back on tight. This way you will have eliminated this possibility. The reason I'm saying this is because it happened to my daughter on her way to work when she turned right and hit a manhole cover at the same time the car died. When I got there the car was dead lifted the hood and found the boost post snug but I could undo it with my fingers. Snugged it up started the car and drove it home where I put the wrench to it. Never died again since and this happened last spring.
