05 Cobalt Key is Stuck in Ignition
05 cobalt automatic,key stays in ignition.i messed with the brake pedal shifted P to 1 back & worth ignition on & off.I 've check Park pin cleaned inside console no dirt dust or sticking.This is a common problem anyone know how to fix it?? eventually something clicks. I know about the override switch under the steering column to get the key released. I want to fix it correctly. GM tells me to replace the shifter assembly.They should replace it ,if it is a defect. I have 2 cobalts & they both do it periodically. I cant figure out what to replace and spending a lot of cash on guessing isn't my way of doing things! Thanks, Mitch
