I have a few questions. I'm pretty much set to wire everything up....but
what sources can I use for the two 30amp(fuses) red wires for the remote starter module. It says (battery, but im not sure which wires would be safe to use)
thanks for the help
---------- Post added at 01:23 PM ---------- Previous post was at 01:03 PM ----------
Also, the purple tach ac wire from the remote starter, its an prostart 3371. in the ADS AL GM2 it says to connect the tach ac output to the tach ac input on the starter
just confused on what to do.
iDatalink - ADS-AL CA
wiring type 1
http://www.engines911.com/asdocs/CT-...s43_110607.pdf
