Fan Blower Motor Problems - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 8 (permalink) Old 12-03-2012, 12:57 AM Thread Starter
Hi, ive been reading and searching the forum alot but i cannot find any answers for my problem. I have a 2006 ls coupe 2.2l and the blower motor works on and off. Ive checked fuses and relays, they are all good. Ive noticed the connector for the blower motor is loose both where it plugs in and the wires inside. Ive wiggled the wires and connector and it works on and off until i hit a bump or sometimes it just turns off. Any one have any ideas? It is truly a PITA dealing with it. Again when it wants to work the fan settings (1-4) work great, it blows cold or hot depending on the setting. It just doesnt want to play nice all the time. Any help you guys can provide would be greatly appreciated.
Btw the wires in the connector look to be exposed for 1/8 inch and semi corroded(ie not shiney copper anymore)
thisguy2424 is offline
post #2 of 8 (permalink) Old 12-03-2012, 04:19 AM
You seem to be talking about the fan speed resistor network located at the bottom of the heater box. You will need to replace the resistor network to fix this.
https://www.yourcobalt.com/forums/pro...t-service.html
post #3 of 8 (permalink) Old 12-03-2012, 05:11 AM Thread Starter
Uh replace everything or what? Cuz everything works if i fool around with the power connector for the blower motor. The resistor should be working if it turns on and operates from 1-4 after i found the spot the power connector wants to work at, right?
---------- Post added at 05:11 AM ---------- Previous post was at 04:45 AM ----------
Just pulled the power plug and it looks a little melted on the upper wire on the female connector...
post #4 of 8 (permalink) Old 12-03-2012, 05:48 AM
Sorry man but these do fail and the only solution is to replace it. I know GM don't give it away, but sometimes you just have to bite the bullet.
---------- Post added at 09:48 AM ---------- Previous post was at 09:45 AM ----------
You can always go
Chevy Cobalt 05-10 Heater Resistor, Power Transistor 52416143, A271 | eBay
Standard Motor Products RU464 HVAC Blower Motor Resistor Chevrolet Cobalt HHR | eBay
post #5 of 8 (permalink) Old 12-03-2012, 06:43 AM Thread Starter
It actually wasnt the resistor. Just got one from oriellys plugged it in and nogo. Then i tried jiggling the connector that runs from the resistor to the motor and boom turned on. Any clue where i could get a new connector?
post #6 of 8 (permalink) Old 12-03-2012, 11:12 AM
Levee
Admin
Leveecius's Avatar
Sounds like a short to me. Is it actually by a connector or is it in the middle of the wire somewhere? Also, I saw you post that something looked a little burnt, anyway you could post a picture of that?
'09 SS/TC - Stolen
06 EVO IX MR/SE - Sold
'95 Ram 2500 Diesel
Speed Junkies Social Group
Leveecius is offline
post #7 of 8 (permalink) Old 12-03-2012, 12:30 PM
Might just be a broken wire at the connector.
post #8 of 8 (permalink) Old 12-03-2012, 10:49 PM Thread Starter
Yeah ill try to figure out how to post something with my iphone. The connector that runs from the resistor to the blower motor itself is semi charred. Im thinking it could be a short too since the wires are a little exposed at the base of the connector. Ill post a picture in a few hours after i get done working. Oh one quick question the emis fuse, a red 10a next to a relay in the fuse box under the hood, if it were blown could that give me a few cels?
