05' Oil Leak: Driver's Side Above(and Left) of Oil Pan - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 10 (permalink) Old 01-01-2013, 02:39 PM Thread Starter
My cobalt started leaking oil Friday. I dropped the oil pan yesterday and replaced the seal. Filled oil back up and drove around the block a few times. Leak has returned. It is not the oil pan. It is above the oil pan and more towards the left. Any Ideas? Crank Shaft Seal?[COLOR="Silver"]
See Arrow pointing at the gap behind the bolt with oil on it...
---------- Post added at 02:39 PM ---------- Previous post was at 02:38 PM ----------
[IMG][/IMG]
DLoTiger22 is offline
post #2 of 10 (permalink) Old 01-01-2013, 03:39 PM
Levee
Admin
Leveecius's Avatar
Can you take a shot that is a little less zoomed so we can see more clearly where youre talking about.
'09 SS/TC - Stolen
06 EVO IX MR/SE - Sold
'95 Ram 2500 Diesel
Speed Junkies Social Group
Leveecius is offline
post #3 of 10 (permalink) Old 01-01-2013, 06:56 PM
could be your rear main seal
post #4 of 10 (permalink) Old 01-01-2013, 07:46 PM Thread Starter
This is further back. The oil appears to be running down the walls. Just behind the exposed gear/flywheel on the drivers side of the engine.
[IMG][/IMG]
post #5 of 10 (permalink) Old 01-02-2013, 11:27 AM Thread Starter
How can I confirm rear main seal leak?
post #6 of 10 (permalink) Old 01-02-2013, 11:42 AM
Levee
Admin
Leveecius's Avatar
Pull off transmission inspection cover, spray rear of engine with degreaser, let sit for 10 minutes, spray off with water, drive the car for a little bit (usually around 50-100 miles), then recheck with inspection cover off. If it's leaking there, you have a leak there, if not, then it's not. That is the easy way.
Or you can buy the oil dye, put it in the system, drive for 100 miles and use a black light and look for where the dye is coming out of. that is another way of doing it.
'09 SS/TC - Stolen
'95 Ram 2500 Diesel
post #7 of 10 (permalink) Old 01-02-2013, 01:41 PM Thread Starter
Bar's Rear Main Leak Seal okay for now?
post #8 of 10 (permalink) Old 01-02-2013, 05:40 PM
Anything you do will only slow it down if its a rear main seal. May aswell just buy the seal.
post #9 of 10 (permalink) Old 01-14-2013, 09:59 AM Thread Starter
How difficult of a job am I looking at to reach the seal? Do I have to drop the whole transmission or is there a short-cut to access its location? I don't exactly have easy access to a lift. I've seen where someone pulled the engine out of the top and it only took them 2hrs. Would that be easier to access the seal?
post #10 of 10 (permalink) Old 01-14-2013, 10:20 AM
Pulling the motor and doing the seal and installation was no 2 hr job. You need to pull the transmission and flywheel to change the seal. Save yourself the hassle of trying to find a nonexistent shortcut and just pull the trans
05 oil leak above pan , cobalt oil leak
