Halo Lights - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 7 (permalink) Old 01-11-2013, 12:24 PM Thread Starter
Halo Lights
just installed halo lights with leds now auto headlights do not work, is there a relay. looked in fuse box could not find it
sanman is offline
post #2 of 7 (permalink) Old 01-12-2013, 02:01 AM
Puddle's Avatar
Just checking, this is how you did it right?
1 Turn off your Chevrolet Cobalt and prop open the hood with the hood support rod.
2 Remove the two 10mm bolts on top of the headlight assembly.
3 Pull the headlight assembly toward you, away from the engine compartment, until you can see the wiring harness. Disconnect the wiring harness and fully remove the headlight assembly from the front end of the Chevrolet Cobalt.
4 Connect the wiring harness to the rear of the halo headlight assembly and set the halo headlight assembly on the headlight mounting bracket. Secure the halo headlights with the two 10mm bolts you removed earlier.
5 Repeat the previous procedures for the headlight on the other side of the front end of the Chevrolet Cobalt.
Now check to make sure that the fuse is still ok. It's in the engine compartment fuse box it is the red mini fuse just above the one circled here (next to the word omron) http://i1107.photobucket.com/albums/...elpumpfuse.jpg you can thank Coby7 for the image.
Puddle is offline
post #3 of 7 (permalink) Old 01-12-2013, 10:31 AM Thread Starter
fuse good lights will go on when put in drive but wont time out when i shut off car
sanman is offline
post #4 of 7 (permalink) Old 01-12-2013, 03:51 PM
Puddle's Avatar
Try turning the option of "lights off" in the dash panel.
Puddle is offline
post #5 of 7 (permalink) Old 01-12-2013, 09:29 PM
Puddle's Avatar
I was referring to where you reset the oil and such.
Puddle is offline
post #6 of 7 (permalink) Old 01-13-2013, 07:48 AM
Where did you connect the Halos to.
post #7 of 7 (permalink) Old 01-13-2013, 03:35 PM Thread Starter
hook halo to parking lights in the dic in 09 no option for auyo lights
sanman is offline
