2008 Cobalt with P0411 - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 30 (permalink) Old 01-14-2013, 12:37 PM Thread Starter
Hey guys, purchased a 2008 2.2 with front end damage. The tube from the air cleaner to the air injection pump was bad and we replaced it. Keep getting a P0411 code for the air injection system. I already have done the following:
1) Test air pump relay
2) Test air solenoid relay
3) verified fuse are good
4) verified air pump runs
5) verified air solenoid operates
6) check for leaks
After all these tests I have cleared codes and with in 2-3 days it comes back. I have reviewed all the forums and googled this to wits end. Does anyone have any other suggestions? Thanks!
u19286a1 is offline
post #2 of 30 (permalink) Old 01-14-2013, 01:27 PM
Did you change the pump? It might have been damaged in the accident.
post #3 of 30 (permalink) Old 01-14-2013, 01:31 PM Thread Starter
No the pump was not changed. I did pull it and verify that there wasn't any damage. As well as jumping the relay for the pump. I can here the pump run and when I jump the relay for the solenoid it also works.
u19286a1 is offline
post #4 of 30 (permalink) Old 01-14-2013, 02:29 PM
Well P0411 is Secondary Air Injection (AIR) System Incorrect Air Flow Detected, so kink in the hose or bad pump.
post #5 of 30 (permalink) Old 01-15-2013, 06:24 AM Thread Starter
There is no kink in the hose and when I remove the hose to the check valve and manually operate the pump I feel a large amount of air being blown to the valve.
u19286a1 is offline
post #6 of 30 (permalink) Old 01-15-2013, 08:16 AM
Levee
Admin
Leveecius's Avatar
Coby, according to the DTC list it says it is the secondary air injection system incorrect flow. Not insufficient. Maybe you're getting too much air from the pump or valve.
---------- Post added at 11:16 AM ---------- Previous post was at 11:15 AM ----------
Btw, welcome OP. Hope we can help.
'09 SS/TC - Stolen
06 EVO IX MR/SE - Sold
'95 Ram 2500 Diesel
Speed Junkies Social Group
Leveecius is offline
post #7 of 30 (permalink) Old 01-15-2013, 08:26 AM Thread Starter
Is there some sort of check valves or more to the air pump besides basically a fan blowing air?
u19286a1 is offline
post #8 of 30 (permalink) Old 01-15-2013, 08:33 AM
Levee
Admin
Leveecius's Avatar
Oh yes lol . They should have rheostats built in to them to automatically adjust the fan speed to keep the same flow. If that was damaged, the pump wouldn't be regulated thus be throwing more air than needed.
'09 SS/TC - Stolen
'95 Ram 2500 Diesel
post #9 of 30 (permalink) Old 01-15-2013, 09:01 AM Thread Starter
Oh okay. Thanks! I guess I will wait till the cel goes on again and then if it does pull the pump inspect and or replace.
u19286a1 is offline
post #10 of 30 (permalink) Old 01-15-2013, 09:02 AM
Levee
Admin
Leveecius's Avatar
More than likely will be replace as 99% of rheostats are internal. Just some fyi. And you're welcome.
'09 SS/TC - Stolen
'95 Ram 2500 Diesel
