Inner Tie Rod Torque?? - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 10 (permalink) Old 01-14-2013, 06:53 PM Thread Starter
Does the inner tie rod have a torque spec where it attaches to the rack and pinion?
Hogpaw is offline
post #2 of 10 (permalink) Old 01-14-2013, 07:06 PM
I always put them in crazy tight. Haven't had a problem. There probably is a torque amount, hell there's a torque amount for a valve cap
post #3 of 10 (permalink) Old 01-14-2013, 08:31 PM
stratosproject's Avatar
My manual says 25 N.m (18 lb ft) plus 90 degrees for the outer tie rod, but lists no spec on the inner. It just says to tighten the bolt.
stratosproject is offline
post #4 of 10 (permalink) Old 01-15-2013, 08:15 AM
Since GM replaces the whole rack when an inner tie-rod goes bad there is no listing for torque specs in the manual.
post #5 of 10 (permalink) Old 01-15-2013, 03:11 PM Thread Starter
Thank you for the help
Hogpaw is offline
post #6 of 10 (permalink) Old 01-15-2013, 03:29 PM
Normally you pull it tight and bend the keyed washer on 2 sides over nut, this stops the inner tie-rod from working itself loose.
post #7 of 10 (permalink) Old 01-18-2013, 12:16 PM Thread Starter
Follow up: The paperwork in the Moog box states the inner tie rods are to be torqued to 53 ft/lbs. with loctite on the threads.
Hogpaw is offline
post #8 of 10 (permalink) Old 01-18-2013, 01:59 PM
Does it also have the metric value for us Canadians, it would be in Nm?
post #9 of 10 (permalink) Old 01-18-2013, 02:44 PM
Re: Inner Tie Rod Torque??
I'm Canadian and I use ft.lbs
post #10 of 10 (permalink) Old 01-19-2013, 12:03 PM Thread Starter
53 ft/lb = 71.8 Nm.
Hogpaw is offline
