Crank but NO Fire - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 10 (permalink) Old 01-27-2013, 02:44 PM Thread Starter
Crank but NO Fire
Recently, my 2005 Cobalt had thrown a error with engine power reduced. shut it down- waited for a few minutes started back up and it was fine. Drove it for a few days fine. Today went out to start the car and all I have is a starter crank and humming fuel pump. I get no fire no turnover. I think it could be the coil/plugs Ive checked the wire connector on the side and its tight. The motor still has its original plugs in it at 140K there never was any acceleration issues so i was told leave the plugs alone until you get hesitation when stepping on the gas. I was however getting some RPM issues when slowing to a stop. The cars throttle body was cleaned once but has since acted up with the real cold weather. now the car just won't fire period. Any suggestions on this guys? I appreciate the insight and help
TopSpinJay is offline
post #2 of 10 (permalink) Old 01-27-2013, 03:22 PM
My first guess would be crank position sensor. What was the dtc?
post #3 of 10 (permalink) Old 01-27-2013, 03:37 PM Thread Starter
I could not get the code off the car yet ...hasnt been to the shop and i was stupid to not stop at a auto zone thinking things were fine. now i can't move it to get the code off cuz the thing wont start. go figure id screw that up lol
post #4 of 10 (permalink) Old 01-27-2013, 06:07 PM
Car won't start if ignition module doesn't know when to fire. Crank position sensor tells the "PCM" where #1 piston in relation to cam, then PCM can send ignition signal to ignition module with right timing.
post #5 of 10 (permalink) Old 01-28-2013, 04:03 PM Thread Starter
thanks for the clue on this situation...its going to the shop tomorrow so i should know more then and will share the news when I get it
post #6 of 10 (permalink) Old 01-29-2013, 01:27 PM
What did you find out today, TopSpinJay?
Sarah, GM Customer Service
post #7 of 10 (permalink) Old 02-01-2013, 08:22 AM Thread Starter
The timing chain tensioner said goodnight. It's a estimated 1900 repair to machine rebuild and fix the top of the engine so I'm essentially dead in the water and its very disappointing
post #8 of 10 (permalink) Old 02-01-2013, 10:00 AM
Bummer, cheaper to change the engine.
post #9 of 10 (permalink) Old 02-03-2013, 06:51 PM
tntorqu's Avatar
coby7 have you ever had to change the timing chain on your yet?
tntorqu is offline
post #10 of 10 (permalink) Old 02-03-2013, 07:00 PM
No but I think BankerBalt did his.
