Ignition/Steering - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 6 (permalink) Old 01-27-2013, 06:44 PM Thread Starter
Ignition/Steering
2008 cobalt lt, automatic
Ignition would not turn and brake very stiff..
attempted jiggle key and move wheel at same time, no effect. turned wheel fully right, no effect and wheel locked.
removed hatch under wheel and pressed white button. no effect.
Please Advise.
Thank you.
tapandrack is offline
post #2 of 6 (permalink) Old 01-27-2013, 06:58 PM
Not sure I understand. If you can't depress brake pedal you won't be able to turn the key. Almost sounds like you have wrong key in ignition. White button is to release ignition barrel to release key not vice-versa. Check fuses for brake switch, because it releases ignition and shifter. Check ignition switch.
post #3 of 6 (permalink) Old 01-27-2013, 07:04 PM Thread Starter
I see, white button was the wrong route.
The key is correct and i used the spare..
I'm in the manual looking for the breaks switch fuse and cant locate. where do i locate this? once located what do i do with it? take out and put back in?
post #4 of 6 (permalink) Old 01-27-2013, 07:37 PM
Verify that your high brake lamp comes on when you press brake pedal. Fuse 9 of BCM fuse block (10 amp). If it's burnt replace it if it's good re-insert it in place and go to next step.
It could also be fuse 8 ignition switch (2 amp).
Even "BCM2 fuse 40amp" in the underhood fuse block.
---------- Post added at 10:37 PM ---------- Previous post was at 10:35 PM ----------
Does your dome light come on?
post #5 of 6 (permalink) Old 01-28-2013, 01:13 PM
tapandrack,
Any updates? Let me know if I can be of any assistance (primarily, I can answer recall/warranty questions or help you in working with a dealership).
Sarah, GM Customer Service
post #6 of 6 (permalink) Old 01-28-2013, 05:02 PM Thread Starter
Hi again!
Well this morning i took my moms car to work. Later i asked her to get my car towed to the mechanics. She got everything in place and decided to test the car and for some odd reason, key turned, engine on, wheel unlocked, break works.
The mechanics said it could be a battery dying and to replace it myself to save a significant amount of cash
