Dead Battery? - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 15 (permalink) Old 02-15-2013, 06:03 PM Thread Starter
JosephN79's Avatar
Dead Battery?
First off . . my car was wrecked in september . . and has been sitting in my drive since then. It started when I moved it off the road after the accident, and it started when the tow truck driver drove it to the spot in my drive where it currently sits.
Im selling it tomorrow (hopefully) . .. I went out today and hooked up jumper cables to it to jump it, since the battery is dead. When I hook up cables . . everything lights up, blowers work, dash works . . . dome lights . . etc . . . i can hear the fuel pump pressure up as well.
I go to start it . . and I get a rapid and loud *Click click click . . * repeatedly. When thishappens all my lights flicker. when theclicking stops . . Ive let it sit fr about 15 min *charging* while hooked up to another running car . . but still the same thing occurs.
I can hear something kind of *winding down after the clicking stops when i let off the key . . .
Please tell me this is just a dead battery . . .
thank you.
JosephN79 is offline
post #2 of 15 (permalink) Old 02-15-2013, 06:35 PM
Tap on the starter solenoid with hammer. It probably rusted a bit enough to stop it from actuating.
post #3 of 15 (permalink) Old 02-16-2013, 07:48 AM Thread Starter
JosephN79's Avatar
where is this? . . . Can i get to it without opening my hood . . my hood is crushed shut .. . I only got to the positive terminal and strut mount bolt because the hood is that buckled up lol
post #4 of 15 (permalink) Old 02-16-2013, 08:05 AM
You can get at it from the bottom front. Just jack front drivers side.
post #5 of 15 (permalink) Old 02-16-2013, 10:31 AM Thread Starter
JosephN79's Avatar
I got under there andsomeone turned the key . . i can hear the starter tapping loudly . . . but not cranking . . . couldnt find the sloenoid . . . would it stil be a solenoid issue if the starter is tapping like that? I hit on it maybe to loosen something up . . the starter imean . .. but it never did anything
---------- Post added at 01:09 PM ---------- Previous post was at 01:08 PM ----------
also . . I got my hood opened . . . he brought a new battery as well . . still acted the same . .
---------- Post added at 01:31 PM ---------- Previous post was at 01:09 PM ----------
i the solenoid the smaller of the 2 canisters of the starter?
post #6 of 15 (permalink) Old 02-16-2013, 10:49 AM
Yes, but what you hear is the solenoid so it must be the bendix itself that is stuck. Tap on the starter with a hammer you won't hurt it. If it doesn't budge you'll need a starter or a bigger hammer.
post #7 of 15 (permalink) Old 02-17-2013, 01:29 AM
Etnies's Avatar
dude just charge it longer.....its been completly dead for a long time so its gonna take a while
Etnies is offline
post #8 of 15 (permalink) Old 02-17-2013, 05:08 AM
Send a message via AIM to Oldkid
Etnies is right. Unless you have very large jumper cables, all the power is going to the dead battery, with not enough left over to crank. It needs to be charged, or left on the jump car at least 45 minutes.
Oldkid is offline
post #9 of 15 (permalink) Old 02-17-2013, 01:27 PM Thread Starter
JosephN79's Avatar
Alright... I tried to tap on it... I'll charge it longer as well... Thanks... I guess it doesn't matter if you jump it off a fresh battery if yours isn't charged fully, I let it charge 15 min... I'll try
45... I appreciate it...
---------- Post added at 04:27 PM ---------- Previous post was at 04:13 PM ----------
sory if im showing my ignorance, should I tap it while i try to crank or not while im cranking it? thanks . . .
post #10 of 15 (permalink) Old 02-17-2013, 02:30 PM
Originally Posted by JosephN79 View Post
sorry if I'm showing my ignorance, should I tap it while I try to crank or not while I'm cranking it? thanks . . .
Nobody is born knowing all. Actually some are but they're on a different forum.lol
Don't matter for the tapping, but it's more like hitting it than tapping. It probably rusted a bit.
