Bad Amp? - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 19 (permalink) Old 04-16-2013, 01:25 PM Thread Starter
Bad Amp?
So, I have a kenwood 12" woofer set up in the back powered by a kenwood class D 1000W mono amp. For a long while, it worked. It wasn't pretty, it was the first thing I'd ever done to mod any car, but it worked. A friend of mine who installs car electronics for a living offered to clean up my wiring for me. he did that, and now you can barely tell that there are wire, however shortly after, the amp stopped working. I have it unhooked from a fuse right now, but when it is hooked up, the amp comes on (power signal light lights up at least) and stays on for a little while, but when I start playing music, as the woofer draws poser to kick, the power signal light starts to flicker, and soon dies and the woofer stops kcking. I havent found the time to actually try and figure out what is the prolem, but I figured I would post here to see if anyone has any ideas.
P.S. stock head unit, signal is tapped into Alpine 6x9's in the back.
Corran54 is offline
post #2 of 19 (permalink) Old 04-16-2013, 02:01 PM
Rriggs92's Avatar
Check the ground first
Sent from AutoGuide.com App
Rriggs92 is offline
post #3 of 19 (permalink) Old 04-16-2013, 02:27 PM Thread Starter
Ground is good. It's screwed into the metal sidewalling.
Corran54 is offline
post #4 of 19 (permalink) Old 04-16-2013, 04:52 PM
Rriggs92's Avatar
Did you check it? Or are you telling me where it's grounded?
Check all the wires into the amp as well as fuses in it if yours has any
Rriggs92 is offline
post #5 of 19 (permalink) Old 04-16-2013, 04:59 PM
Jmesl8er's Avatar
Whats your gain on?
Jmesl8er is offline
post #6 of 19 (permalink) Old 04-16-2013, 05:00 PM
Rriggs92's Avatar
Originally Posted by Jmesl8er View Post
Whats your gain on?
Yea if its up to high it will probably cut out and not work as well
Rriggs92 is offline
post #7 of 19 (permalink) Old 04-16-2013, 05:10 PM
Jmesl8er's Avatar
Also the way you have it hooked up to the head unit isn't very good. Signal sucks. Go out and buy a 100 dollar head unit at Walmart
Jmesl8er is offline
post #8 of 19 (permalink) Old 04-16-2013, 09:28 PM
Rriggs92's Avatar
Whoa now. While that hu would be better its still not worth wasting a Hundo
He is right about the signal though. Get a nice stereo
Rriggs92 is offline
post #9 of 19 (permalink) Old 04-17-2013, 06:50 AM Thread Starter
It's grounded well.
I'll check my gain after school and let you know after school.
all the wires and fuses are good.
Signal might suck, but it works just fine when the amp is on.
Corran54 is offline
post #10 of 19 (permalink) Old 04-17-2013, 08:23 AM
Jmesl8er's Avatar
Originally Posted by Corran54 View Post
It's grounded well.
Hook it up to a head unit and you'll see a big difference.
Jmesl8er is offline
