P0446 code - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 14 (permalink) Old 04-20-2013, 12:48 PM Thread Starter
P0446 code
I know that this situation has been posted before in the forum but one really posted a fix or results of their fixes.
My 2008 Cobalt LT2 has been giving me the P0446 code for the last day or 2. I checked the purge valve by trying to blow air through it using my mouth but nothing would go through (unhooked completely) Then i looked at the canister under the car ran a bench test on the vent valve and it works fine opens and closes as its suppose to. theres a 3 prong hook up on the canister i dont know what that is alittle insight on that would be great. I blew light air through the vent pipe thinking there was a blockage. Is there anything else i should try before i start ripping parts?
THIS IS MY FIRST POST BUT IVE BEEN LOOKING AT YOUR FORUMS FOR A WHILE DECIDED ITS ABOUT TIME TO SIGN UP.
PitbullMean is offline
post #2 of 14 (permalink) Old 04-20-2013, 02:18 PM
My daughter just came home with the Cobalt and the check engine light was on. Same code I will work on this and let you know.
• DTCs P0106, P0107, P0108, P0112, P0113, P0117, P0118, P0121, P0122, P0123, P0128, P0222, P0223, P0443, P0449, P0452, P0453, P0455, P0496, P0502, P0562, P0563 are not set.
• The ignition voltage is between 11-18 volts.
• The barometric pressure (BARO) is more than 68 kPa.
• The fuel level is between 15-85 percent.
• The estimated ambient air temperature is between 2-32C (35.6-90F).
• The start-up ECT and estimated ambient air temperature are within 9C (16.2F) of each other.
• The vehicle speed sensor (VSS) is less than 1.7 km/h (2 mph).
• The purge solenoid valve is enabled.
• DTC P0446 will attempt to run up to 10 times until it successfully completes.
• DTC P0446 completes one test per trip when the above conditions have been met.
The fuel tank pressure (FTP) sensor is more than 3 inches H2O vacuum for 4 seconds during the 10 minute test.
Action Taken When the DTC Sets
DTC P0446 is a Type B DTC.
Conditions for Clearing the MIL/DTC
Diagnostic Aids
• An intermittent condition could be caused by a damaged EVAP vent housing, a temporary blockage at the EVAP canister vent solenoid valve inlet, or a pinched vent hose. A blockage in the vent system will also cause a poor fuel fill problem.
• An EVAP canister filter that is restricted can cause this DTC to set.
post #3 of 14 (permalink) Old 04-20-2013, 03:40 PM Thread Starter
Alright coby thanks
---------- Post added at 06:40 PM ---------- Previous post was at 06:09 PM ----------
The only other thing I can think of is my fuel tank pressure sensor but the only code is p0446 nothing else
post #4 of 14 (permalink) Old 05-02-2013, 01:05 PM
Well got the code (P0446) again finally today, so cleaning connectors and vent lines did nothing for me, although it's been almost 2 weeks since last CEL. so I purchased Vapor Canister Solenoid Valve today and will install it as soon as I can get my hands on the car.
post #5 of 14 (permalink) Old 05-04-2013, 09:57 AM
OK, pulled old evap solenoid out this morning. Once I unlocked it by turning counter clockwice 90 it practically fell out. After testing the old one and found it to work OK, I didn't think this was my problem but since I had already purchased a new decided to install the new one. This is when I realised that what the problem might be was leaking "O" rings. As the old one came out very loosely the new one needed pursuasion to insert into place. Now it's a waiting game to see if CEL is going to come on again.
---------- Post added at 01:57 PM ---------- Previous post was at 01:55 PM ----------
Not convinced that this will solve my problem with the P0446 code.
post #6 of 14 (permalink) Old 05-04-2013, 04:10 PM
Code's back. F&%/"
post #7 of 14 (permalink) Old 05-05-2013, 08:48 AM
This is when a smoke test will come in handy
09 SS/TC 4DR G85
dawkness is offline
post #8 of 14 (permalink) Old 05-05-2013, 09:44 AM Thread Starter
Did you take the canister off the car. and shake it sometimes charcoal breaks loose. also take off your purge valve and clean that. if that doesnt work smoke test it
post #9 of 14 (permalink) Old 05-09-2013, 07:07 AM
Update. Yesterday, morning I changed the purge valve under the hood and cleared the code. I drove the car all day yesterday and my daughter has it today. It's a waiting game now but again doubth this is my problem since old purge valve seems to work fine on the workbench. Unless the "O" rings are wore out at the fitting.
This is the old purge valve.
Just have to pull on locking clip to remove from bracket.
---------- Post added at 11:07 AM ---------- Previous post was at 11:04 AM ----------
If this fails I will disassemble Canister and shake loose carbon out of it if any.
post #10 of 14 (permalink) Old 05-11-2013, 12:30 PM
Well code came back today so disassemble Evap Canister from it's location and found the pressure sensor almost pulled out from it's position. As far as I can see it's only press fit, so I removed it and greased the "O" rings and put everything back together. Also vacuumed the foam filter inside the canister it was pretty black. Sorry, I failed to take pictures, too concentrated on the fix. Next time I will for sure. One bolt holds the canister in place, of course it broke.
Let the waiting game begin again.
