Top of Gas Tank is Leaking - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 10 (permalink) Old 04-28-2013, 01:58 PM Thread Starter
Ok, so I recently noticed when I park the cobalt in the garage the garage smells like gas. I put the rear on ramps and seen there is a wet spot coming from the top of the gas can. I can't see where it is coming from from up top, too small of a gap from bottom of car and the top of the tank. But I can clearly see it is coming from up top. I can see the gas coming down on the front side and the rear side. I was thinking about removing the four bolts that hold the two straps that hold the tank up and put a jack under the tank to support it and lower a little to see if I can see what is going on...What do You think??
Also, I noticed my front passenger side halfshaft seal seeping a little. What should I look for right there to confirm it is the seal? If I pull the shaft, Does the seal come out easy?
Any help would be appreciated...Thanks!!!
DjOrionXTR is offline
post #2 of 10 (permalink) Old 04-28-2013, 02:03 PM
There is a recall on the fuel pump gas line leak.
https://www.yourcobalt.com/forums/rec...ar-2013-a.html
I assume you mean differential seal so yes that is an easy enough fix with proper tools. Pull the shaft, rip the old seal out and tap the new seal in, re-install shaft.
post #3 of 10 (permalink) Old 04-28-2013, 07:46 PM Thread Starter
wow. Thanks for the input!! ill be calling my chevy dealer tomorrow. Even if it out of warrenty, they will still take care of the recall?
post #4 of 10 (permalink) Old 04-29-2013, 04:03 AM
Yes, even if it is a silent recall.
post #5 of 10 (permalink) Old 04-29-2013, 08:10 AM Thread Starter
I'm going to have to fix this myself. I already can play out what is going to happen. Im going to drop of the car, they going to tear it down. Then they going to find something wrong that isnt due to a recall and then now I have no choice but to pay them for the work they have already done. Or to go ahead and pay for the whole job that wasent related to the recall. 'm not going to know if it is recall realted untill they pull the gas tank down. And then to hope its some recall related. If its not then I have no choice but to pay them for pulling down gas tank. So, to cut all that hassle out. I will have to do this myself.
post #6 of 10 (permalink) Old 04-29-2013, 08:39 AM
Hi DjOrionXTR,
I would be happy to check for recalls for you. Can you private message me your VIN please? Also to answer your question, yes GM will take care of recalls. Look forward to hearing from you.
Crystal L-GM Customer Care
post #7 of 10 (permalink) Old 04-29-2013, 02:52 PM Thread Starter
[QUOTE=ChevyCustSvc;652785]Hi DjOrionXTR,
Crystal L-GM Customer Care[/QUOTE
Won't let me, says I have to have 10 posts.
post #8 of 10 (permalink) Old 04-29-2013, 08:44 PM Thread Starter
It still says the same thing.
post #9 of 10 (permalink) Old 04-30-2013, 06:09 AM
Just call a dealer with your vin...
---------- Post added at 08:09 AM ---------- Previous post was at 08:06 AM ----------
Dealers can't fix anything without your permission. If they do, and try to charge you with it, then you can tell them you didn't want them to fix it. They will either keep the part there free of charge to save the hassle or replace with old part. And if somethings wrong that wasn't before, I'd sue
post #10 of 10 (permalink) Old 04-30-2013, 10:01 AM Thread Starter
i called my dealer and they just said, "oh, well just bring it by". I always know how that turns out.
